replacing distributor cap and rotor, will timing change?
Old May 13, 2005 | 09:09 PM
ice11honda's Avatar
Default replacing distributor cap and rotor, will timing change?
I just changed my wires, dizzy cap and rotor. I made sure the new rotor went back on in the same place old rotor was at. Will my timing remain the same or will it have changed? Thx
Old May 13, 2005 | 09:25 PM
cruizinmax's Avatar
Stays the same. I would probably check it anyways if you are doing a tune up.
Old May 13, 2005 | 09:37 PM
nocturnaldragon's Avatar
Default Re: replacing distributor cap and rotor, will timing change? (ice11honda)
I belive you can only put it back on one way. Either case ive never heard of it changing by doing such.
Old May 13, 2005 | 10:49 PM
Archidictus's Avatar
Unceasing Measure
Default Re: replacing distributor cap and rotor, will timing change? (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">I belive you can only put it back on one way.</TD></TR></TABLE>
Truth.
Old May 13, 2005 | 10:53 PM
Andres-eh2's Avatar
to be on the safe side, i always draw a mark on top of the dizzy that crosses to the other side as a reference
Old May 14, 2005 | 05:45 AM
ice11honda's Avatar
Default Re: (Andres-eh2)
Awesome!! Thankyou all for the help. I an not so confudent some times and it is good to have othrs reassurance. Thx again.
Old May 14, 2005 | 05:47 AM
HATCHingMN's Avatar
Default Re: (ice11honda)
it will stay the same ....unless you turn the whole distributor LEFT or RIGHT
Izo
May 22, 2011 07:54 PM
B18C5er
Nov 15, 2004 05:20 PM
Xxcivic99xX
Oct 24, 2004 01:07 PM
uNF$@#!
Mar 28, 2004 11:48 PM
