Most efficient Cams with stock 10:1 compression in a GSR with bolt ons.......
Old May 13, 2005 | 09:07 PM
ScottFern's Avatar
Default Most efficient Cams with stock 10:1 compression in a GSR with bolt ons.......
I am looking for the best and most aggressive cams that work best with stock compression b18c1 motor.
Let me know what you guys recommend??
Skunk2 Stage 1s
Rocket M22s???
Old May 13, 2005 | 09:41 PM
UncleD's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (ScottFern)
Uh, neither. Stock type r cams are more than worthy for this motor....
Old May 13, 2005 | 09:59 PM
hondaeg8's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (clean rice)
you should be good with the s2s1's, but i wouldn't go any higher than that.
CTR or ITR cams would do good also.
just do what i'm going to do and boost it
Old May 13, 2005 | 11:01 PM
Boostfed's Avatar
New User
CTR cams!!! Seen it many a times on the dyno, people with very mild set ups trying to run too big of cams then swap to CTR just kill sall midrange and up top righ there with them. Skunk1 and Skunk2s I have seen
Old May 13, 2005 | 11:08 PM
Tbone's Avatar
m22's are way too big for that setup..
If you get skunk stg 1's make sure you have some sorof way to change your vtec as it will bog because the x-over will be to low.
I'd say ctr or itr.
I know Boostedhybrid tuned an internally stock gsr with buddyclub 3+ cams and was in the 170 range before he sprayed nitrous. That was with just a plain dc 2 1/4 header with an exhaust and intake.. I was surprised
Old May 14, 2005 | 09:06 AM
ScottFern's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (Tbone)
Well right now I have S2S2 cams & S2 cam gears, along with portflow titanium retainers and portflow valve springs.....and I really want to go with a less aggressive cam......
So right now it seems like S2 Stage 1s or CTR cams. These cams I have now are total overkill, but then another question arises.
Can I run S2 Stage1s or CTR with titanium retainers and portflow valve springs?
Old May 14, 2005 | 09:20 AM
AllMotoRex's Avatar
I'm running m22's with stock b18c1 for now.. stil getting little bugs out but it feels alot better then stock gsr cams.
Old May 14, 2005 | 09:54 AM
ScottFern's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (AllMotoRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotoRex &raquo;</TD></TR><TR><TD CLASS="quote">I'm running m22's with stock b18c1 for now.. stil getting little bugs out but it feels alot better then stock gsr cams. </TD></TR></TABLE>
Is the idle lumpy? Are M22s made for 11.X+ compression ?
Old May 14, 2005 | 10:00 AM
ScottFern's Avatar
What do you guys have to say about the BC3+ or M22X for 10:1 compression motor?
Modified by ScottFern at 1:13 PM 5/14/2005
Old May 14, 2005 | 02:31 PM
ScottFern's Avatar
I guess I am looking for towards a Skunk2 Stage 1...
Old May 14, 2005 | 02:38 PM
Y2K Si FBP's Avatar
mill the head...alil (for assurance) and add a mugen headgasket. toss the stage 2's in there...with 10.6 compression (stock) and a mugen HG...no miling or head work made 198 whp and 131 wtq. skunk stage 2's are an awesome cam
Old May 15, 2005 | 06:45 AM
smkngsr's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (Y2K Si FBP)
im not sure if Mugen headgasket is really that good...i mean they are durable i dont think they perform really well on dyno...my tuner said that its harder to tune when u mill the head or use a thinner headgasket because not everything is aligned on the timing...correct me if im wrong...thanks
Old May 15, 2005 | 07:33 AM
moto1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottFern &raquo;</TD></TR><TR><TD CLASS="quote">I guess I am looking for towards a Skunk2 Stage 1...</TD></TR></TABLE>
I have set of CTR's and need something more...maybe we could work something out. moto1320@yahoo.com
Old May 15, 2005 | 07:58 AM
ScottFern's Avatar
Default Re: Most efficient Cams with stock 10:1 compression in a GSR with bolt ons....... (moto1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto1320 &raquo;</TD></TR><TR><TD CLASS="quote">I have set of CTR's and need something more...maybe we could work something out. moto1320@yahoo.com</TD></TR></TABLE>
I think I am looking for something just a little more aggressive then CTRs. I've decided to go with BC3+s. ANy feedback on the BC3+s ?
Old May 19, 2005 | 09:37 AM
del5ol's Avatar
sorry to ***** ur thread.. but ill be getting some s2s1 cams my setup on stock compression is with the s2 manifold and my vtec x over is at 5800 runnning a chipped p28. is that a good setup to run the s2s1 cams?
phelpsj2
11
Dec 19, 2010 02:18 PM
cdfran
May 19, 2008 07:13 AM
cdfran
May 10, 2008 06:03 PM
Easyslider01
May 6, 2005 10:11 AM
hondaeg8
Mar 31, 2005 02:53 PM
