loose rear view mirror
Old May 13, 2005 | 04:30 PM
DBOT's Avatar
Default loose rear view mirror
can someone please help and tell me how to fix my loose rear view mirror. its the "ball and socket" type joint that is loose. it moves all the time when i close my doors and any sudden movements. so basically i have to adjust it all the time.
Old May 13, 2005 | 04:34 PM
Slammed Ek9's Avatar
Default Re: loose rear view mirror (fourstar)
there should be a screw in the back of the mirror but you have to remove a small plastic cover. then you will find either an allen screw or a star screw either one if you tighten it.... it will tighten your mirror right up.
Old May 13, 2005 | 05:13 PM
DBOT's Avatar
do you know how to remove that small plastic cover. do i just use a screw driver to pop it off or something.
Old May 13, 2005 | 05:14 PM
yea just use a screw driver there should be a small insert on the bottom to get it off
cdizzle's Avatar
well ya??
a small one
slowexcoupe
11
Apr 6, 2011 05:42 AM
SyDuck
Jun 1, 2005 10:43 PM
citanest
Oct 27, 2001 04:51 AM
