For Those Using the Toyo RA-1 Track Tire
Old May 13, 2005 | 04:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default For Those Using the Toyo RA-1 Track Tire
You may have noticed that the Toyo RA-1 is now sold with a UTQG treadwear rating of 100 on the sidewall. Before this year, it had a treadwear rating of 40.
I just sent their technical folks the following question:
"I noticed that this tire recently changed from a 40 treadwear rating to 100. Is this because the design and engineering of the tire actually changed, or is it still the exact same tire but you decided to change the treadwear rating after further testing?"
I received the following response:
"It is the exact same tire we just decided to change the tread wear rating after further testing and feedback from consumer track use."
Track on...
Old May 13, 2005 | 04:20 PM
splitime's Avatar
Default Re: For Those Using the Toyo RA-1 Track Tire (nsxtasy)
Heh... i wonder what the rating goes to once shaved
Migs and NTB rock on
Old May 13, 2005 | 04:38 PM
Bbasso's Avatar
Default Re: For Those Using the Toyo RA-1 Track Tire (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">
Migs and NTB rock on </TD></TR></TABLE>
Old May 16, 2005 | 02:34 PM
TypeRTexan's Avatar
Default Re: For Those Using the Toyo RA-1 Track Tire (Bbasso)
Gee, I got at least 6 or 7K out of mine on the street.....
dumkopf
11
Oct 6, 2008 05:40 PM
nsxtasy
May 15, 2005 01:55 AM
Neo79Si
May 5, 2005 04:51 AM
LJRACER
Jun 4, 2004 08:48 AM
SpoonEK2
25
Apr 5, 2003 09:39 AM
