What is this plug? what does it do?
straight forward title, I have this plug unhooked in my car - I found out that it connects to a cylindrical piece obove the clutch pedal. Does anyone know what the plug is or what it does?
I was told because it is yellow that it is SRS related.
here are the pics:
the connector plug
where it goes
here are the pics:
the connector plug
where it goes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">ya i believe the SRS system is labled in bright yellow.
100% sure.. btw looks like the cluster plug or it connects to the airbag if your vehicle is not equipped with one.</TD></TR></TABLE>
thats what I thought, but the air bag system also has the yellow lume around the wires, this doesnt.
I has been pointed out that it looks like the clutch inhibiter as seen here:
http://www.hondaautomotivepart...PEDAL
--- A 2nd saftey switch that prevents the car from starting without the clutch engaged. Usuallly installed with remote starts.
-- like JDmotorsports said.
That's what I was thinking. WTF is there a sensor doing mounted onto a clutch pedal? I guessed cruise so when you depress the pedal, it goes off. But, I never had cruise, so I don't know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 »</TD></TR><TR><TD CLASS="quote">That's what I was thinking. WTF is there a sensor doing mounted onto a clutch pedal? I guessed cruise so when you depress the pedal, it goes off. But, I never had cruise, so I don't know.</TD></TR></TABLE>
I do have it, that yellow plug is crimped so the two wires are together - constant acuation.
if cruise doesnt work then maybe. but honda uses 2 switchs on manual pedal sets. 1 switch is for clutch safety, the other is for cruise safety. dan happens to have a remote start installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EeeJayEight »</TD></TR><TR><TD CLASS="quote">anything with a yellow harness is srs... dont mess with it unless u know about it...</TD></TR></TABLE>
that would wrong. srs has yellow plug&loom and usualy also labeled as srs. we already determined what it is. just because a plug is a certain color doesnt mean much. factorys reuse surplus parts all the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmotorsports »</TD></TR><TR><TD CLASS="quote">
that would wrong. srs has yellow plug&loom and usualy also labeled as srs. we already determined what it is. just because a plug is a certain color doesnt mean much. factorys reuse surplus parts all the time.</TD></TR></TABLE>
im going with this response, I uncrimped the wires and the car didnt (with the clutch un-engaged) start - re-crimped them and it started (with the cluch un-engaged).
I did have an SRS light on, but that was for a different reason, and it is gone now - I just literally reset it.
thanks guys for your help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiclets »</TD></TR><TR><TD CLASS="quote">that sthe service plug when you have a srs light on u could hook up you srs scaner and read what the problem is u could also reset the srs system triugh the same plug
no, i already reset the srs and know it's not that plug
</TD></TR></TABLE>no, i already reset the srs and know it's not that plug
darkmentality
Feb 6, 2013 05:10 PM
kenny707
Feb 9, 2009 09:43 PM
mrbsponge
Apr 18, 2006 04:11 AM
