what is error code 5?
Old May 13, 2005 | 03:44 PM
drewboy's Avatar
Default what is error code 5?
im receiving error code 5 on a ZC DOHC motor with pm6 ecu? thanks
Old May 13, 2005 | 03:55 PM
SiR Inspired ED7's Avatar
Default Re: what is error code 5? (drewboy)
Here ya go:
Code 0______Faulty ECU
Code 1______Oxygen content
Code 2______Does not appear to exist
Code 3______MAP sensor
Code 4______Crank angle sensor
Code 5______MAP sensor again
Code 6______Coolant temperature
Code 7______Throttle angle
Code 8______Top dead center sensor
Code 9______No. 1 cylinder position(only on 1.6L)
Code 10_____Intake air temperature
Code 11_____Does not appear to exist
Code 12_____Exhaust gas recirculation system
Code 13_____Atmosphric Pressure
Code 14_____Electronic air control (EACV)
Code 15_____Ignition output signal
Code 16_____Fuel injector
Code 17_____Vehicle speed sensor
Code 18_____Does not appear to exist
Code 19_____Lock up control solenoid (auto trans only)
Code 20_____Electric load
Old May 13, 2005 | 03:58 PM
FalkenSiR's Avatar
Default Re: what is error code 5? (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">Here ya go:
Code 11_____IMA Sensor (w/o cat engines)
Fixed that up for ya
Old May 13, 2005 | 03:59 PM
Default Re: what is error code 5? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed that up for ya </TD></TR></TABLE>ok, thanks
Old May 14, 2005 | 08:37 AM
drewboy's Avatar
awesome, thanks guys.
next question, on an obd0 vehicle (89 crx hf) where the heck is the map sensor? Usually its on the tb, but im not seeing one.. Please help me out.
Old May 14, 2005 | 09:25 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (drewboy)
Here ya go:
Code 2______2nd Oxygen Content on JDM B16
Code 3______Electrical prob.MAP sensor
Code 5______mecanical prob.MAP sensor
Code 21_____VTEC (spool) solonoid (vtec motor only)
Code 22_____VTEC oil presure switch (vtec motor only)
ifxed it up even better and added
the map sensor is eather mounted on the firewall or in a box on the fire wall. it is kinda square and has a 3 wire plug with a vacume line going to it.
Old May 14, 2005 | 09:25 PM
FOMULA91's Avatar
Default Re: (DieMaster)
Check this out.
http://www.honda.co.uk/owner/C...6.pdf
and
http://www.honda.co.uk/owner/C...4.pdf
Old May 14, 2005 | 10:03 PM
drewboy's Avatar
thanks formula 91, fixed the prob today, a vacuum hose was hidden and not connected.
vtc-gn2
Mar 29, 2005 07:01 PM
h22acivichybrid
Jun 3, 2004 03:24 PM
Me2
Apr 11, 2004 03:13 PM
4gnhatch
Jun 2, 2003 12:35 PM
drunk
Oct 20, 2002 03:29 PM
