ITR bearing color question
Old May 13, 2005 | 01:37 PM
fullboostin's Avatar
Default ITR bearing color question
Currently replacing the main and rod bearings on my 01' itr. Does anyone know the colors on the main and rod bearings since it will probably be a few days untill i get them out?
Old May 13, 2005 | 01:51 PM
Batoutahell's Avatar
Default Re: ITR bearing color question (fullboostin)
You need to check the bearing codes printed on your block and your crank, then refer to the chart in Helms to determine your specific bearing colors.
Old May 15, 2005 | 07:52 AM
Default Re: ITR bearing color question (Batoutahell)
thanks, just wondering if maybe all the 01' itr's were the same and hopefully someone who has done this before can tell me the colors.
Old May 15, 2005 | 08:57 AM
92TypeR's Avatar
FSAE
Main bearings use the same color system as the GSR, so just find a Helms manual for any year integra and it will have the bearing color chart for the mains.
Straight from the ITR Helms manual. (Rod bearings)
Old May 15, 2005 | 02:18 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fullboostin &raquo;</TD></TR><TR><TD CLASS="quote">thanks, just wondering if maybe all the 01' itr's were the same </TD></TR></TABLE>
They are not. Every engine is unique-sort of. For instance, if all of my 01 ITR main bearings are green, yours could be all brown, or a mix of different colors.
j spec
Mar 7, 2007 03:24 PM
jdmhatch94
Sep 13, 2003 02:03 PM
Teg15
Sep 1, 2002 01:12 PM
LSR 97
Jul 18, 2002 11:07 AM
t
Oct 4, 2001 09:20 PM
