griding, uhh adjust clutch? help please...
Old May 13, 2005 | 01:24 PM
mawkiemarc's Avatar
Default griding, uhh adjust clutch? help please...
so im driving home from the dragstrip and i come to find out that when i have my car at WOT and go to hit 3rd, it grinds a good amount. next, as i see it as a bad thing i go to downshift into 2nd and it grinds a lot to. and to top it all off, as i was staging at the burnout lines, my car wouldnt go into 1st, as i would let my foot off the clucth, it would grind. i had to shift into 2nd and back into 1st to even try and slam it into gear. my dad said something about adjusting the clutch, and me being new to driving standard tranny's, i dont know what the hell that means or how to go about doing that. its a 89 civic si hatch with 200 grand on the motor. help please id really appreciate it, thank you...
Old May 13, 2005 | 01:43 PM
limpy's Avatar
Default Re: griding, uhh adjust clutch? help please... (mawkiemarc)
where is a pic ***** when you need them?
but if you open the hood you will see a long cable that goes across the motor to the tranny, then there will be a black plastic nut that goes around the cable. pull up on the relese lever arm on the tranny and then tighten the nut... that will take all of the slack out of your clutch.
Old May 13, 2005 | 04:18 PM
SuperSteve737's Avatar
I was never able to pull up on the lever arm from the tranny, I was just able to tighten the nut. HTH
Old May 13, 2005 | 09:21 PM
limpy's Avatar
Default Re: (SuperSteve737)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSteve737 &raquo;</TD></TR><TR><TD CLASS="quote">I was never able to pull up on the lever arm from the tranny, I was just able to tighten the nut. HTH</TD></TR></TABLE>
when you pull up on it , it wont move but it lets just enough slack out of the cable to make tightening it easier. you can just tighten the nut but i thought it easier to pull on the release lever also.
Old May 14, 2005 | 06:04 AM
Oh, I thought I was just a big puss. LOL.
Old May 14, 2005 | 10:15 AM
mawkiemarc's Avatar
if i tighten the nut and it still doesnt go away, the grinding i mean, would i need a new clutch or tranny?
Modified by mawkiemarc at 2:29 PM 5/14/2005
you were refering to the nut on the right correct? bc my ***** all rusted and old and i cant really tell which ones black....
Modified by mawkiemarc at 2:31 PM 5/14/2005
Old May 15, 2005 | 08:17 PM
mawkiemarc's Avatar
bump.
Old May 16, 2005 | 09:25 AM
FalkenSiR's Avatar
Default Re: (mawkiemarc)
You can see it better in the first pic. Just follow the cable, how hard can that be. Even if you are blind you could do it!!
Old May 16, 2005 | 03:40 PM
mawkiemarc's Avatar
Default Re: (fast88std)
yea i know if i was blind i could do it i just dont wanna mess up bc i have never done something like this. but thanks for the input. if this doesnt work, are there any other things i could do to try and fix my problem or would i juss have to go and buy a new clutch or tranny? help please thanks.....
Old May 16, 2005 | 03:54 PM
Look at your motor.
Look closer.
Even closer.
Even closer than that.
Turn that plastic net.
Old May 16, 2005 | 06:08 PM
mawkiemarc's Avatar
hey thanks man, that helped me the best. i really appreciate that.....
Old May 16, 2005 | 06:52 PM
coot_er's Avatar
look at the first pic that mawkiemarc posted. i think he was trying to tighten the bolt to the right of were the cable goes into the arm. lol thats could be why it didn't help
Old May 17, 2005 | 07:08 PM
mawkiemarc's Avatar
yeah thats the bolt i thought he was refering to, now that someone actually showed me i know how to do it the right way.....
Old May 17, 2005 | 07:21 PM
Old May 17, 2005 | 07:41 PM
mawkiemarc's Avatar
ha what does that mean?....
Old May 18, 2005 | 06:49 PM
I dunno, i like beer.
Old May 18, 2005 | 07:30 PM
mawkiemarc's Avatar
must be nice, lol wish i was 21 so i could legally get it
Old May 22, 2005 | 06:39 PM
mawkiemarc's Avatar
which way do i turn the plastic nut
Old May 23, 2005 | 03:55 PM
mawkiemarc's Avatar
why did u send me a PM of my thread....?
Old May 23, 2005 | 04:00 PM
mrtoastyjr's Avatar
what are you trying to acheive? if you turn the nut UP the threaded shaft the clutch will engauge sooner, or closer to the floor. i think you might want to go the other way. that will let the clutch fully disengauge, therefore no more grinding.......hopefully
Old May 24, 2005 | 04:34 PM
mawkiemarc's Avatar
well if its grinding, whcih way would i turn it or heres a better question, how would i know so engage sooned or later...?
Old May 24, 2005 | 07:20 PM
Skip's Avatar
Turn it clockwise.
Old May 25, 2005 | 04:50 PM
mawkiemarc's Avatar
Default Re: (Skip)
thank you thats all i needed to know. i really appreciate your help
bump for a good person....
Old May 25, 2005 | 09:04 PM
I PM'd it to you so you would check it right away, it seemed like a nice thing to do. Just trying to help you solve your problem a little quicker.
Old May 26, 2005 | 05:17 PM
mawkiemarc's Avatar
oh thanks man, good lookin i see what ya mean how i get it a lil faster.
ok well this is what i have done, i turned that **** to the right (clockwise) and it got rid of the 1st gear problem where i put have to shift into 2nd first but now thats gone. but still grinds when downshifting from 3rd to 2nd. could that just mean i need a new clutch of is my tranny bad....?
