A small quick question.
How long would a easy swap like a B16A into a EG hatch would take. Lets say the person works 2-3 hours a day? ALso into a shell, so no taking out the engine first.
Wait, the question is how long does it take to put in a motor? Like no motor in the car but the motor is laying infront of the car?
I could get that in in half a day, up and running.
Edit: Read it wrong, if you work on it in 2 to 3 hours with about 3 people you could do it in one sitting depending on your skill level.
yeah, its not that hard at all (depending on the person at least). personally, i could probably get it in and running in about 3 hours if nothing breaks and if nothings missing. most of the time, you might run into a problem but in this case, that motor and that car belong together so it should be pretty straight forward, good luck!
half a day, but if your only going to work on it 2-3 hours a day then it will take you 2 days depending on how long you mess around not doing anything
maybe 24-48hrs
depends how knowledgeable u are.
and if u have help, its always good to have another person there
even if there not helping.
u never know what can happen.
IheartSpoon
Aug 1, 2002 10:30 PM
