b18b and b18c1
Old May 13, 2005 | 09:35 AM
lavo81's Avatar
Default b18b and b18c1
ok my friends teg isnt in the best of condition the block (ls) has had it. we searched on here and found nothing about putting a b18b head on a b18c1 block. if he did this he obviouly wouldnt rev any higher than normal ls engine should. on a compression calculator it came up w/ around 11. something to 1 compression if u had b18b head and b18c1 block. he plans on getting a b18c1 head when he gets cash but for now he needs a block and can only afford the block . can he do this or is there gonna be valves hitting pistons or something like that? what timing belt would be best for this?
Modified by lavo81 at 1:46 PM 5/13/2005
Old May 13, 2005 | 09:42 AM
IggyBcool's Avatar
ur post makes no sense
Old May 14, 2005 | 03:40 AM
longbeachpurplecivic's Avatar
Default Re: (99whitejizzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99whitejizzer &raquo;</TD></TR><TR><TD CLASS="quote">ur post makes no sense</TD></TR></TABLE>
he's asking if youre able to put the ls head on gsr block.. and possibly instruction on how to do it?? ( i dunno) and hes wondering if he will encounter any internal problems.
Old May 14, 2005 | 06:51 AM
HoUTX98GSR's Avatar
Default Re: b18b and b18c1 (lavo81)
you want to put the b18c1 head on the b18b block dude.. not the other way around.. and i think you use the b18c1 timing belt and water pump.
Old May 14, 2005 | 07:03 AM
ALMXDUPINTEGRA's Avatar
Don't waste your time putting a B18B head on a B18C block. Aint worth the time and effort.
Old May 14, 2005 | 07:07 AM
lavo81's Avatar
Default Re: b18b and b18c1 (HoUTX98GSR)
he needs a new block its shot. he wanted a gsr so he figured he would get the block then the head later
Old May 14, 2005 | 07:21 AM
redDAinteg's Avatar
weird. i would love to see what numbers you get from that.
Old May 14, 2005 | 07:26 AM
LittleJohn1084's Avatar
lol never heard of this bein done but who knows could turn out pretty good.
Old May 14, 2005 | 07:27 AM
matto2413's Avatar
Default Re: b18b and b18c1 (redDAinteg)
that is weird i never heard of anyone doing that. its usually the other day around
Old May 14, 2005 | 07:28 AM
lavo81's Avatar
Default Re: b18b and b18c1 (matto2413)
yeah, i searched found it i think the compression jumps to 11 or 10
Old May 14, 2005 | 10:08 AM
lavo81's Avatar
or at least thats what it said on a compression calculator depending how accurate it is
Old May 14, 2005 | 11:55 AM
Mr_Moos's Avatar
Default Re: b18b and b18c1 (skylinedo)
What if you had a built B18b head could you put the GSR block in and rev to 8k
Old May 14, 2005 | 12:29 PM
lavo81's Avatar
Default Re: b18b and b18c1 (Mr_Moos)
but the point of this is to get the car running (to get to work) then get the gsr head (b/c its better) and have a gsr in the integra
Old May 14, 2005 | 03:00 PM
jaydeemmmm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skylinedo &raquo;</TD></TR><TR><TD CLASS="quote">gsr/non-vtec</TD></TR></TABLE>
^ That's what I was thinking. I'm the opposite. LS/V with GSR head.
Old May 15, 2005 | 11:13 AM
Mr_Moos's Avatar
Default Re: b18b and b18c1 (jaydeemmmm)
Will it work?
Old May 15, 2005 | 11:39 AM
IggyBcool's Avatar
it would probably work, u would have to have the ls ecu though
Old May 15, 2005 | 11:57 AM
lavo81's Avatar
thats not a problem b/c its a stock ls integra, would i use the gsr or ls timing belt?
Old May 15, 2005 | 12:28 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (lavo81)
The belt might depend more on what oil/water pump you'll have in it?
I'd go with a gsr belt if both pumps are gsr though.
Old May 15, 2005 | 12:42 PM
lavo81's Avatar
Default Re: (FlatBlackTeg)
ok thanks , any other info on this is welcome
Old May 15, 2005 | 12:52 PM
Mr_Moos's Avatar
What headgasket would you use?
Old May 15, 2005 | 01:03 PM
saleensolution's Avatar
Default Re: (Mr_Moos)
you should be able to do it. use a gsr timing belt because the water pump it bigger.( the ls are smaller so if you have a ls use the ls timing belt). im guessing that you would use a ls head gasket for the time being but you may have to block off the extra oil and coolant holes on the block or you will prolly have some leak issues. good luck
Old May 15, 2005 | 01:45 PM
lavo81's Avatar
Default Re: (saleensolution)
ohh thanks for that reminder about pluging the holes forgot about that (what would i use?)
Old May 15, 2005 | 01:49 PM
i cant remember if they completely round or not but i would try threading it and putting in a npt (national pipe thread) plug so that you can take it back out when yoiu put your vtec head back on
Old May 15, 2005 | 01:56 PM
lavo81's Avatar
ok, still open for suggestions
Old May 15, 2005 | 02:00 PM
riceball777's Avatar
dude
just do the opposite of an lsvtec
1 you have to tape (1/8 npt) and plug the vtec oil passage on the vtec block. you do this because on vtec motors vtec is activated with an oil passage from the block to the head. for lsvtec the ls block does not have this oil passage so you plug the head so it does not leak and get the oil from the oil pressure sensor. but for this since the head does not have the passage you plug the block and you do not need to do any oil lins cuz you dont have vtec
2 You have to machine the ls head to accept dowels on the exhaust side (opposite of lsvtec). the dowels holes on a vtec block is on the exhaust side and on a ls block its on the intake side so you machine the ls head to take dowels on the exhaust side or you use lsvtec dowels on the exhaust side.
3 you use ls head studs
i think that should be it both the ls and vtec ecu will run the car but it probably will not run right and its going to be basically going to be the same speed as a ls motor.
i'm not sure what head gasket you would use. i know for lsvtec you use a ls head gasket but i supose for this you would use a vtec head gasket but i'm not 100% sure cuz no one does this.
cr will be about .3 higher than a ls motor but it will be destroked a little. and your vtec wires will just be hanging somewhere and the knock sensor is useless
