Should I upgrade my Exhaust Housing?
Old May 12, 2005 | 11:57 PM
Endoe's Avatar
Default Should I upgrade my Exhaust Housing?
I got a RH kit.... it came with a gt30R dual ballbearing with a .48 exh housing... my friend is telling me the reason why my turbo is spooling so fast is because my exhaust housing is small.. it is rated only at .48ar..... will it make a different if i change it to .61ar.... do you think its worth it to change it....how will it effect my performance and will it lag?
Old May 13, 2005 | 10:49 PM
Endoe's Avatar
Default Re: Should I upgrade my Exhaust Housing? (Endoe)
do they make one for 5 bolt pattern?
Old Jun 12, 2005 | 04:46 PM
Endoe's Avatar
Should i upgrade?????????????Help...
Old Jun 12, 2005 | 04:52 PM
RacerXI's Avatar
By a general rule, the a/r is a trade-off. The smaller a/r tends to spool faster and the power levels off earlier. By the same token, the larger a/r spools later and usually will carry the power higher than most stock valvetrain cars rev. I'm not really sure what you're asking. Most of us end up with mods to help our turbos spool.
Old Jun 12, 2005 | 04:59 PM
Endoe's Avatar
Default Re: Should I upgrade my Exhaust Housing? (RacerXI)
Is it worth it to change my exhaust housing.... what can i expect if i change it to .60ar compare to .48ar on HP and torque...? I Just dont want to be dissapointed if i get it tune with this setup and found out i am making less horse because of my small exhaust housing...i think it is suppose to come with a bigger air ratio but i found out too late to exchange...
Old Jun 12, 2005 | 05:02 PM
Bailhatch's Avatar
If you have traction problems shifting the power band up with bigger turbine housing will make you faster by improving traction and potentially making bigger peak #s. .63 a/r is probably what your next biggest size is btw. What motor is this.
Old Jun 12, 2005 | 06:48 PM
gearhead313's Avatar
25 Year Member
You can get the housings pretty cheap. Get it, put it on and find out for yourself. Some turbo's I keep 4-5 different housings for 2-3 wheels per housing!
Old Jun 12, 2005 | 10:48 PM
Endoe's Avatar
Default Re: (gearhead313)
its a 00 stock LS.....450DSM injectors..GT30R .60ar..RH piping..RH intercooler...
Old Jun 18, 2005 | 07:53 PM
Tchleung's Avatar
well what numbers is your LS putting down right now? got a dyno chart so we can see?
Old Jun 18, 2005 | 07:56 PM
wantboost's Avatar
Who is Mr Robot?
yea, get the .63 ar. with the ball-bearing turbo you wont notice much more lag. a couple hundred rpm at most
Under_Pressure
Dec 22, 2008 01:14 PM
JShull
Sep 28, 2008 01:26 PM
b16hybridsol
Jan 10, 2006 11:36 PM
jackhunt321
Sep 21, 2005 06:38 AM
