DIY painted sideskirts gone horribly wrong....
alright everyone a while back I decided to paint match the sideskirts to my Flamenco Black Pearl 96 Lude. I bought $70 dollars worth in supplies from paintscratch.com. I bought 1 can of primer, 1 can of basecoat, and 1 can of clearcoat, hoping this would be enough. I also bought the waterproof sandpaper.
Ok so I cleanded and sanded the skirts, then applied 3 light coats of primer and let it dry for a while. After the primer was dry, I sprayed them with 3 coats of the FBP basecoat, until my rattlecan ran out. I let the basecoat dry overnight. The basecoat looked dark and evenly applied after I let it dry. This is where everything went wrong. The next day, I started applying the clearcoat. As I was applying the clearcoat it looked alright, but didn't quite look dark enough. As the clearcoat started drying, it lost its shine, and the paint was like a gray-black color! WTF!!!
Anyone have any ideas of what went wrong, I followed all the directions exactly from paintscratch.com, and the directions on the back of the cans.
I think you need to buff the paint to get the gloss. Use some light compound and see if that helps. I believe Paintscratch.com paint is a lacquer based which needs to be buffed to get the gloss after you're done.
Good luck.
Good luck.
99Ek_Fred
Nov 5, 2016 09:17 PM
