MPFI question for the pros
Old May 12, 2005 | 06:39 PM
90HatchSTD's Avatar
Default MPFI question for the pros
alright i got a question for all you pros at doing the mpfi thing. I have a 90 hatch that i did the mpfi swap to last year. I think somewhere in my wiring is screwed. I have followed all the links on here i have found for the swap but now i have one question. At the ecu, pin c2 origanally had a white wire going to it. I think that white wire was for the crank angle sensor. WHen you do the mpfi swap you are suposed to put the blue/yellow wire from the dizzy in position c2. Now my question is where do you put that white wire? I think i have my wiring routed wrong because since i have done the mpfi swap the motor wont take a full 100% rev without boggin and i have been goin through distributors like gas. Any clues. I've searched and cant seem to find anyone with my same problems
Old May 13, 2005 | 04:30 AM
EFvtec Yo!'s Avatar
Default Re: MPFI question for the pros (90HatchSTD)
BUMP
Old May 13, 2005 | 04:39 AM
d16efsedan's Avatar
Default Re: MPFI question for the pros (EFvtec Yo!)
https://honda-tech.com/zerothread?id=639552 https://honda-tech.com/zerothread?id=945557 i searched for these for ya,if they dont help search MPFI and also look in the FAQ section. good luck
Old May 13, 2005 | 05:48 AM
EFvtec Yo!'s Avatar
Default Re: MPFI question for the pros (rexwreck)
hey man, thanks alot. I think you just helped me figure this out. I think i acutally rode around for a year with that white wire hooked up at c2 when it should have been at b12. I dont see how the car was even running. Thanks Alot
Old May 13, 2005 | 08:57 AM
AychTwenee2's Avatar
B10 and B12 are your cyl pos sensor wires. So the white would go to B10 i believe and orange to B12. c1 and c2 are your crank position sensor wires.
Ryan Sexton
May 11, 2018 08:46 AM
JJ's civic
May 6, 2009 02:55 PM
blackmugensivic
Jun 27, 2007 02:43 PM
