ITR Rotor Thickness
Old May 12, 2005 | 06:13 PM
ericlee303's Avatar
Default ITR Rotor Thickness
Folks, thanks for your help. Someone wants to buy my old ITR front rotors for a project, but they first need machining.
I don't want to sell them to him if they are too thin to be machined. What is the min thickness of the rotors before they can't be machined anymore?
Thanks!
Eric
Old May 12, 2005 | 06:15 PM
BlueR's Avatar
Default Re: ITR Rotor Thickness (ericlee303)
edit...sorry about that
RIF
Modified by BlueR at 11:48 PM 5/12/2005
Old May 12, 2005 | 07:10 PM
Mythias's Avatar
The min is 21mm, IIRC.
Old May 12, 2005 | 07:45 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: ITR Rotor Thickness (BlueR)
mythias is correct. The minimum spec is 21 mm for the front rotor. It's 23 mm thick when new. The rear rotor is 9 mm thick when new, and minimum is 8 mm. These specs are on page 3-13 of the '98 service manual.
Modified by nsxtasy at 8:22 AM 5/13/2005
Old May 12, 2005 | 07:48 PM
BlueR's Avatar
Default Re: ITR Rotor Thickness (nsxtasy)
i need glasses and a new brain
Old May 12, 2005 | 08:54 PM
migs's Avatar
Minimum machine to is .830"
Once you are near 2 thousandths, you should plan on replacing them.
Old May 13, 2005 | 07:36 AM
ericlee303's Avatar
Thanks everyone, this really helps alot!
Weel
18
Oct 21, 2010 05:18 PM
supra360
May 13, 2008 09:09 AM
Bruce Banner
Jan 21, 2007 12:31 AM
My95SlvrBlt
Welding / Fabrication
Oct 10, 2006 04:36 PM
meanteg
Feb 13, 2003 08:38 AM
