Wierd Noise from My 95 LS---- Attached is 13 mb video file to help diagnosis. H
Old May 12, 2005 | 05:22 PM
WTB AUTO EK's Avatar
Default Wierd Noise from My 95 LS---- Attached is 13 mb video file to help diagnosis. H
My whole engine shakes when this happends. I dont know what it is. I put in new spark plugs, and wires but it didnt fix it. Theyre in tight and the plugs are gaped right so I dont know what it is.
13MB file. AVI format. Any Ideas what I can use to compress this, just in case I want to do this again?
http://savefile.com/filehost/p...50524
Old May 12, 2005 | 06:47 PM
Default Re: Wierd Noise from My 95 LS---- Attached is 13 mb video file to help diagnosis. H (SSImpala)
anyone?
Old May 12, 2005 | 07:10 PM
sykotic's Avatar
I can't view the video
Old May 12, 2005 | 07:36 PM
PLAGUED_DB7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sykotic &raquo;</TD></TR><TR><TD CLASS="quote">I can't view the video</TD></TR></TABLE>
X2
Old May 12, 2005 | 08:52 PM
Default Re: Wierd Noise from My 95 LS---- Attached is 13 mb video file to help diagnosis. H (PLAGUEDDB7)
dam it works for me...
click on the link..then click on the big download button...then itll have a link that says "download now"
i used my digital camera to copy it..
let me see if i can put it in another format or something..
Old May 12, 2005 | 10:14 PM
no2unenolife's Avatar
i also can't see the video
try using
yousendit.com
Old May 12, 2005 | 10:28 PM
redDAinteg's Avatar
Default Re: (no2unenolife)
cant see it says error
Old May 13, 2005 | 09:48 PM
Tegra's Avatar
Default Re: (redDAinteg)
That's pretty "wierd." Like a thumping sound. More info on the car (as in miles, etc.) would be helpful.
With it not being consistant, my best guess is a problem with the cat. It could be clogged or partially clogged. When pressure builds, it "bubbles" out. It could also be a mild backfire (checked timing?). Have you noticed a decrease in performance?
Old May 13, 2005 | 09:50 PM
Tegra's Avatar
Default Re: (Tegra)
...or maybe someone is clubbing a seal next to your car.
Old May 15, 2005 | 08:06 PM
Default Re: (Tegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tegra &raquo;</TD></TR><TR><TD CLASS="quote">That's pretty "wierd." Like a thumping sound. More info on the car (as in miles, etc.) would be helpful.
With it not being consistant, my best guess is a problem with the cat. It could be clogged or partially clogged. When pressure builds, it "bubbles" out. It could also be a mild backfire (checked timing?). Have you noticed a decrease in performance?</TD></TR></TABLE>
my car is automatic. all stock and has about 170k on it. the stuttering and quivering/bogging only occurs when the car is hot. the puttering noise thats coming out of my exhast only happends when its hot. I heard the cat only works when the car is hot. What do you guys think?
im thinking its time to replace the cat. someone suggested replacing the o rings on the fuel injectors, but i dont have any leaks etc. can they be clogged?
jkn1515
Honda Motorcycles
Oct 7, 2005 03:47 PM
Jose-aka-Pedro
Oct 3, 2005 05:19 PM
