6th gen h22 swap - harness/ecu question
i've searched the h22 swap and haven't really found a clear answer. usually it has the run down of everything in the engine bay, but when the swap is done, are you using the prelude ECU or the accord ECU? and if i wanted to keep it OBD II, would i get a prelude or accord AEM EMS? anyone with clear knowledge of this, please let me know. thanks.
You'll need a Prelude ECU. If you want to keep it OBD II, get an ECU from a '96 Prelude, b/c it's the only one that's OBD II and doesn't have the immobolizer system. I really don't see the need for the AEM EMS unless you're going for a serious NA build or going turbo.
CR-V-tech
Feb 5, 2008 09:24 AM
