My 94 hatch oversteers too much...how to avoid
Old Feb 4, 2002 | 03:56 PM
jonnybravo's Avatar
Default My 94 hatch oversteers too much...how to avoid
Will a front sway bar help? I have front and rear strut bars and also have a rear lower tie bar. I also have no power steering and tanabe sustec suspension. Help please.
Old Feb 4, 2002 | 03:57 PM
jonnybravo's Avatar
Default Re: My 94 hatch oversteers too much...how to avoid (jonnybravo)
ttt
Old Feb 4, 2002 | 05:02 PM
gamby's Avatar
Do you have a stock rear sway? ( a fatter one makes you oversteer)
Run your rear shocks at full soft and your fronts a bit harder than full soft, tinker from there.
Is your alignment in check?
Rear tires worn/old and hardening???
hth
Old Feb 4, 2002 | 06:13 PM
BARF1's Avatar
Default Re: My 94 hatch oversteers too much...how to avoid (gamby)
wow .... an oversteer civic ......
and he didn't mention anything about having a rear sway bar ....
check condition of tires .... tire pressure ..
shocks setting ... a soft rear setting should take out the oversteer ...
Old Feb 4, 2002 | 06:20 PM
Yesman's Avatar
New User
-stiffer springs in the front and softer springs in the back
-invest in 26mm front sway bar
-reduce the size of your rear sway bar
this should help create some understeer if not neutralize you setup.
tell...
Old Feb 4, 2002 | 06:26 PM
jgale's Avatar
step on the gas...
Old Feb 4, 2002 | 09:15 PM
silo's Avatar
i wish i was in your position i really hate understeer my del sol has factory front-rear sways and it either grips hard or the front end keeps sliding forward....
gotta get some money together for a rear sway heh.......
Old Feb 5, 2002 | 10:51 AM
jonnybravo's Avatar
I have the Skunkworks Rear lower 21mm swaybar.
ribal_gh
Suspension & Brakes
Apr 5, 2014 02:27 PM
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
auto addict
Jul 6, 2008 12:47 PM
lazyxazianxboi
Sep 15, 2004 04:20 AM
Accord94DX
Jul 22, 2002 01:50 PM
