HELP!!! Staring problem
Old May 12, 2005 | 02:19 PM
91jdmzc's Avatar
Default HELP!!! Staring problem
my 91 DOHC ZC civic will, once in a blue moon, decide not to start (never happens in the winter). I went to star my EF after work and it didn't start or turn over the first couple of tries. I kept trying after only hearing the buzzing relay under the dash, then it decided to turn over and then not and then...u get the picture. so I bump started it. Yesterday I went to work and it started. I started it for the gym then to leave the gym the same **** happened. I hit the starter with a hammer, what's the problem????
Old May 12, 2005 | 03:38 PM
crxtreme89h's Avatar
Default Re: HELP!!! Staring problem (91jdmzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmzc &raquo;</TD></TR><TR><TD CLASS="quote">HELP!!! Staring problem</TD></TR></TABLE>
Blink damnit blink!!!!
J/K
Anyways, I think you will solve your problem by replacing your ignition switch.
Old May 12, 2005 | 04:42 PM
P.S.I Garage's Avatar
i have a staring problem 2, everytime i see a fine chick!
Old May 12, 2005 | 04:51 PM
SwissChEz82's Avatar
Default Re: HELP!!! Staring problem (turbo b20 gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo b20 gsr &raquo;</TD></TR><TR><TD CLASS="quote">i have a staring problem 2, everytime i see a fine chick!</TD></TR></TABLE>
But seriously, check your grounds check your battery connection too, I had the same problem for a couple weeks and found it to be as simple as the connection to the battery was too loose.
Old May 12, 2005 | 05:30 PM
1988c-rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo b20 gsr &raquo;</TD></TR><TR><TD CLASS="quote">i have a staring problem 2, everytime i see a fine chick!</TD></TR></TABLE> me too..
id go with the ground wires..
GoCarInteg
Sep 30, 2008 01:26 PM
Slammin585
May 24, 2006 09:54 PM
omar6686
Apr 2, 2005 06:07 AM
92-EG6
26
Feb 26, 2004 10:03 PM
Bizarre
Aug 17, 2003 03:09 PM
