would a gsr oil pan fit a ls block
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrious »</TD></TR><TR><TD CLASS="quote">would an ls oil pan fit a gsr block(bolt right up)?</TD></TR></TABLE>
The bolt pattern is the same, but the LS pan won't fit with the GSR crank girdle and oil pickup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
The bolt pattern is the same, but the LS pan won't fit with the GSR crank girdle and oil pickup.</TD></TR></TABLE>thanks for the reply.
i run a gsr oil pan in my lsvtec and it works fine, i am even useing the ls oil pick up.
the reason i am runing a gsr oil pan is because i have the jdm oem itr 4-1 header and it cant be run with the ls/b16 oil pan because it hit the pan and it was made ofor b18c's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R6 »</TD></TR><TR><TD CLASS="quote">Will a B16 oil pan fit? or do you have to change the pickup and other crap too?</TD></TR></TABLE>
The LS and B16 oil pans are exactly the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Yeah a GSR pan will fit an ls motor just fine. You don't have to change the pick up(Besides they bolt up differently anyways). But an LS pan won't fit a gs-r.</TD></TR></TABLE>
