Electrical Help
I finally got my lude done but I'm having an electrical issue at this time that I need help with.
Engine is built. I've upgraded pretty much everything that needed it. The harness is pretty much stock other than the injector clips, resistor box, 3 bar map sensor and msd sci ignition with coil. I'm running Hondata s200b.
I got the car back after getting a new turbo installed and tuned and it ran great for about a week. i was on my way home from work and the car just died. The shop found the ecu fuse was blown so they replaced it and after 10 miles of driving the car died again. I've gone on the assumption that the problem is in the ignition somewhere so i'm going back to stock. I got a new coil, cap and rotor to hopefully fix this (85k miles and still the original cap and rotor). Now I'm just trying to find the connector from the harness to see if this is the problem. Does anyone have the harness connection to the stock coil for the 5th gen prelude they would be willing part with?
Anyway does this sound like it could be the problem?
