need help with fuel pump install walbro
Old May 12, 2005 | 12:44 PM
type Gendy's Avatar
Default need help with fuel pump install walbro
I'm trying to put my walbro 255 in my 91 crx. I got the tank down and trying to get hte pump out. I took off hte one fuel line on the top cover with the 17mm banjo bolt. How do i get the second fuel line loose? Theres no nut on it??
PELASE HELP...dark ness in 2 hrs
Old May 12, 2005 | 12:48 PM
Deetz's Avatar
Crazy Honda Guy
I think that one is held on as friction fit. I did the swap on mine crx about 6 years ago, i know it works like a charm once installed.
Old May 12, 2005 | 12:51 PM
type Gendy's Avatar
Default Re: (Deetz)
"friction fit"
You mean to just yank it out?
Old May 12, 2005 | 05:46 PM
type Gendy's Avatar
Default Re: (type Gendy)
Whats the deal with the wires just dangling in there and floating in gasoline? That sounds like a ticking bomb?
I cut the harness they provided almost in half, and soddered it to the remaining pump wires...but the harness was still about 6 inches long. Either way, those wires are gonna be submerged...and they only provide you with crimps ?
I dont get how these wires can be submerged in gasoline??
Old Oct 27, 2005 | 05:25 PM
W O T's Avatar
that cant be good
Old Oct 27, 2005 | 05:33 PM
HB VTEC's Avatar
as long as you make sure the connectors are tight..you will not have any problems...don't use electric tape..it will just slide right off
Old Nov 5, 2005 | 01:52 PM
type Gendy's Avatar
Default Re: (electronbluehatch)
woa, gravedig......
but yea, 6 months later i am still alive
JDMho0ked
Jul 31, 2007 10:58 PM
jdm4drSi
Jun 12, 2007 08:21 AM
sssimmon
Feb 26, 2006 08:13 PM
bard329
Feb 15, 2006 07:34 AM
turbod16y7vtec
Sep 29, 2002 10:45 AM
