ground control AND koni yellows
Old May 12, 2005 | 12:08 PM
Nextelbuddy's Avatar
Default ground control AND koni yellows
have a friend with a 97 lude.. wants to go with GC and koni yellows.. shes buying the koni yellows locally and purchasing the GC online.... but i have heard form a select frew that GC/KONI wont work on 97's is this incorrect??
also is there anythign special you need to order to make the koni yellows and GC work well together or wil they both work fine right out of the box ??
Old May 12, 2005 | 12:11 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: ground control AND koni yellows (Nextelbuddy)
i dont see why not people say its one of the best set ups for the money
Old May 12, 2005 | 12:13 PM
Default Re: ground control AND koni yellows (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">i dont see why not people say its one of the best set ups for the money</TD></TR></TABLE>
ok so theres nothing special you have to do when orderijg GC and konis separately? they should mate together just fine??
Old May 12, 2005 | 12:16 PM
raylude's Avatar
just make sure they are for a 5th gen.
is the car a type sh if so the struts maybe different
Old May 12, 2005 | 12:25 PM
yes unfortunately its a SH lol
Old May 12, 2005 | 12:41 PM
JP Page's Avatar
It should work fine, the konis will not work if you use them with stock SH springs. Also, if you do the install you are going to have to pull the radius rods from the ball joints on the front. DO NOT USE A PICKLE FORK! This will mess up the ball joint boot and you will have to replace it. I learned the hard way. The small pitman are puller will work great for this. And if the stud of the ball joint spins while putting the radius rod back on, just get another jack and jack the car up by the radius rod. This should put enough pressure on the ball joing to allow of the tightening of the castle nut.
Just wanted to let you know before you started.
Old May 12, 2005 | 01:31 PM
Default Re: ground control AND koni yellows (JP Page)
will GC coilvers and koni yellows for a base model lude 97 work ona SH lude??
Old May 12, 2005 | 02:04 PM
bad-monkey's Avatar
you must:
a) get the koni specific sleeves from ground control
or
b) get the koni adapter sleeves from ground control.
GC makes a special sleeve for use with koni yellows because the dimensions are different. if you don't use the right sleeve or get the right hardware, the sleeve has the capacity to slide past the circlip causign the suspension to collapse.
as long as you're using new spring perches with the new springs on an SH and not the stock spring perches with the new springs i beleive you can use any prelude suspension on an SH. i'm not an SH guy, but there's something in the SH suspension that has a different radius than most aftermarket parts.
Old May 12, 2005 | 02:07 PM
raylude's Avatar
Default Re: (bad-monkey)
well if anyone knows about this kinda stuff its badmonkey
RHGSR01
Feb 2, 2010 11:01 AM
Chillinit
Suspension & Brakes
Mar 18, 2008 11:53 PM
slowacura
Dec 13, 2003 11:25 PM
Isaac
Mar 25, 2002 10:58 AM
Briman2021
Jan 30, 2002 08:17 PM
