bogging.. then cant start up at all... ??
Old May 12, 2005 | 10:55 AM
DrazoYU's Avatar
Default bogging.. then cant start up at all... ??
i had CEL for (knock sensor 1,bank 1) have no idea what bank 1 is.. anyways.. car started bogging.. id give it a little gas on a pedal, and car would "choke" and power would dramaticly start decreasing.. and i would downshift and it would be fine for a few minutes and again same problem.. just all of a sudden, bogged so much that i cant power on anymore?
fuel bump is working, but there's no fuel to fuel filter when i try to start car?
can someone please help me out.. thx
Old May 12, 2005 | 03:57 PM
DrazoYU's Avatar
Default Re: bogging.. then cant start up at all... ?? (DrazoYU)
any response?
Old May 12, 2005 | 08:51 PM
DrazoYU's Avatar
ttt
Old May 12, 2005 | 09:11 PM
dcfour's Avatar
I had the same problem. I had wierd idle at first. then it started to bog after i clean'd my iacv. the next day everything was fine. that same day went to a friends house. after that tried to start it and it wouldn't start so i had to jump start it. Now i have to replace my alternator.
Old May 12, 2005 | 10:23 PM
sooo_slow's Avatar
New User
Default Re: bogging.. then cant start up at all... ?? (dcfour)
So the fuel pump is working but there's no fuel to the fuel filter???? theres something wrong there, are you 100% certain that the pump is fine???
Old May 12, 2005 | 11:44 PM
DrazoYU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcfour &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem. I had wierd idle at first. then it started to bog after i clean'd my iacv. the next day everything was fine. that same day went to a friends house. after that tried to start it and it wouldn't start so i had to jump start it. Now i have to replace my alternator. </TD></TR></TABLE>
exectly, idle was wierd, i even tried jump start it, no help..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sooo_slow &raquo;</TD></TR><TR><TD CLASS="quote">So the fuel pump is working but there's no fuel to the fuel filter???? theres something wrong there, are you 100% certain that the pump is fine???</TD></TR></TABLE>
yea, i took a little bowl with gas in it, and put the fuel pump in it and it threw the gas out on the other side of it, and before i would start my car, i can hear the pump "spin" noise and stops, so i'm pretty sure its working.. and also w/my air compressor, i used it from my hose where filter is, and i heart pressure in the tank.. so i'm confused.
i think im just gonna set it on fire.. its pissing me off
Old May 14, 2005 | 10:47 AM
sooo_slow's Avatar
New User
So when u try to start it and it doesnt start, do u push on the gas at all?
weaponsgrade
Jan 8, 2010 09:55 AM
red92EG
Jan 16, 2006 07:59 PM
DOHCGsr
Jan 2, 2005 04:50 PM
racingrex
Nov 6, 2003 04:46 PM
