Canadian Civic No ELD (bought one, just need pinout)
I need the pin out for the Electronic Load Detector.
I have a Canadian Honda Civic (1996) that has no ELD. I have swapped
in a JDM B18C1 engine (Acura Integra GSR) and now my ECU has a light on
for ELD (Code 20)
I have purchased another fuse box from eBay that now has the ELD
connector however I do not know the order of the pins for inputs and
output.
1 wire is 12Volt + (Black/White) or (black/yellow)
1 Wire is Ground + (Black)
1 Wire is 5 Volt Output. (Red/Green)
Does anyone know the order of the wires?
Anyone in the USA should be able to just look at the bottom of there
fuse box. I'm sure someone in a shop has a harness lying around they
can look at.
for ELD (Code 20)
output.
can look at.
