CALLING ALL ATS FD OWNERS--need help
Old May 12, 2005 | 08:56 AM
jdmspoonitr's Avatar
Default CALLING ALL ATS FD OWNERS--need help
Well I was just wondering in 5th gear at 4500 rpm on the cluster tach what speed are you guys at?
Old May 12, 2005 | 08:59 AM
Dave_B's Avatar
At 80 mph, a bone stock USM ITR (with 4.4 FD) will turn 4378 RPM in fifth gear, an otherwise stock USM ITR with the 4.785 JDM FD will turn 4760 RPM in fifth gear, and an otherwise stock USM ITR with the 4.9 ATS FD will turn 4875 RPM in fifth gear. These are actual RPM figures, not adjusted for tachometer error. The ITR tach generally reads higher than actual. Other factors can account for error, too; for example, the difference in tire diameter between a new tire and a worn tire is about 2 percent (this affects actual road speed, but not the relationship between revs indicated on the tach and speed indicated on the speedometer). With a number of such variables thrown in, it's difficult to identify and analyze a rev difference as small as 125 RPM.
Per NSXTASY
Old May 12, 2005 | 09:40 AM
Ryan_C's Avatar
Default Re: CALLING ALL ATS FD OWNERS--need help (jdmspoonitr)
I would say you would be running about 77 mph.
Not sure if that is right mathematically, but I think that about what I observed the last time I was experimenting.
You should get one. They are awesome and make driving lots more fun, even on the highway.
Old May 12, 2005 | 09:55 AM
Bbasso's Avatar
http://bob123e.tripod.com/askb...r.htm
Old May 12, 2005 | 10:03 AM
1GreyTeg's Avatar
About 75 mph
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old May 12, 2005 | 10:10 AM
Bradstard's Avatar
Default Re: CALLING ALL ATS FD OWNERS--need help (1GreyTeg)
Check this one out too. Will tell you everything you want to know.
Old May 12, 2005 | 10:14 AM
1GreyTeg's Avatar
Default Re: CALLING ALL ATS FD OWNERS--need help (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">http://bob123e.tripod.com/askb...r.htm</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Check this one out too. Will tell you everything you want to know.
silly wabbits
Old May 12, 2005 | 10:59 AM
Bbasso's Avatar
Bradster just wants to be like me
Old May 12, 2005 | 01:34 PM
Default Re: CALLING ALL ATS FD OWNERS--need help (Bbasso)
Thanks guys!
Old May 12, 2005 | 02:37 PM
kepani's Avatar
here's another one just because it's black.
http://reverendsgarage.net/ind...r.php
kepani
killerB16A
Aug 3, 2006 10:57 PM
black2001ITR
Mar 10, 2004 04:17 PM
Chemicalviper
Oct 21, 2003 10:23 PM
Splat
May 16, 2002 11:49 AM
austrian type-R
Feb 28, 2002 05:33 AM
