Shake when I brake
Old May 12, 2005 | 08:35 AM
dcb284's Avatar
Default Shake when I brake
Whenever i brake my car shakes, not to vibrantly. just a lil. i took my car to my mechanic he said my breaks in the back are fairly new and my front brakes have like 10k miles worth of wear on them. i bought this car a lil bit more than 2 years ago and i havent had to do the breaks yet. what could be causing the car shaking a lil bit? rotors?
Old May 12, 2005 | 08:37 AM
notoriousB's Avatar
Default Re: Shake when I brake (dcb284)
warped rotors perhaps. could be as simple as a tire that's out of balance.
Old May 12, 2005 | 08:52 AM
fuglycord's Avatar
Default Re: Shake when I brake (notoriousB)
if it shakes only when braking more likely warped rotors. if it shakes all the time, then maybe the tires need balancing. try braking with the ebrake and see if it still shakes.
Old May 12, 2005 | 09:07 AM
Turbowa's Avatar
Default Re: Shake when I brake (fuglycord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuglycord &raquo;</TD></TR><TR><TD CLASS="quote">try braking with the ebrake and see if it still shakes.</TD></TR></TABLE>
If it does then it will be your rear rotors being warped. If not then its your front rotors. Also if you steering wheel shakes when braking it will be the front. It the pedal vibrates it could be the back, but e-brake is a better way to tell about the rear brakes.
Old May 12, 2005 | 09:25 AM
YeuEmMaiMai's Avatar
brake rotors need to be replaced. if your car was out of allignment, then it would shake with or without the braikes being applied
Old May 12, 2005 | 10:48 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
You need a new mechanic. The first thing they should have checked was the rotor runout. You have warped rotors. If its very slight, and the metal is not damaged from overheating, they may be able to cut them, OW you need new ones. CHING! CHING!
Old May 12, 2005 | 06:12 PM
i20ar's Avatar
Default Re: Shake when I brake (Hondaman56)
all you have to do is take them to a break shop and get them resurfaced...
Old May 12, 2005 | 07:26 PM
Calean007's Avatar
Default Re: Shake when I brake (14aZnS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">all you have to do is take them to a break shop and get them resurfaced...</TD></TR></TABLE>
Time to get new rotors....you're better off....
Old May 12, 2005 | 07:40 PM
i20ar's Avatar
Default Re: Shake when I brake (Calean007)
4 what?
Old May 13, 2005 | 12:19 PM
Calean007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">4 what? </TD></TR></TABLE>
Because, if your rotors are warping, it's likely to assume his rotors are old anyway. Might as well get new ones with new pads. Don't have to mess with it for a long time...
Old May 13, 2005 | 12:30 PM
i20ar's Avatar
it depends on how old his car is and how much rotor is left.... the reason they could be warped are not based on how old they are but probably becuase of the way he breaks. Warped rotors are caused for heavy breaking from high speeds... theres no reason to by new ones unless they are damaged or unrepairable.. most warped rotors on daily drivers arent bad enough to not be resurfaced.. it would be a waste of money to buy complete new ones if you dont need them.. resurfacing them will make them as good as new
Old May 13, 2005 | 02:10 PM
Calean007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">it depends on how old his car is and how much rotor is left.... the reason they could be warped are not based on how old they are but probably becuase of the way he breaks. Warped rotors are caused for heavy breaking from high speeds... theres no reason to by new ones unless they are damaged or unrepairable.. most warped rotors on daily drivers arent bad enough to not be resurfaced.. it would be a waste of money to buy complete new ones if you dont need them.. resurfacing them will make them as good as new</TD></TR></TABLE>
O.k. you do have a point there, but I guess it comes down to preference.
Old May 13, 2005 | 04:52 PM
i20ar's Avatar
yea it does, but you shouldnt go tell sum1 to go spend money on something they might not need. you could've at least given him an oppinion option instead of just saying you'll need to by new ones.
Old May 19, 2005 | 06:51 AM
vichelm's Avatar
Make sure if you get new tires or have your tires rotated that your lugs are torqued to honda specs. That will cause your rotors to warp. Have you rotors resurfaced first... if their isnt enough there to turn then get new ones. Dont spend the money until you have too.
noss88
18
Nov 26, 2008 11:55 AM
globy123
16
Aug 21, 2007 05:23 PM
WalkerGSR1
Suspension & Brakes
Aug 13, 2006 02:36 PM
jorge99hx
25
Dec 10, 2005 12:52 PM
4doorRS5spd
Feb 25, 2002 08:13 AM
