B16a: Weird Idle after i hit a dip :-(
Old May 12, 2005 | 06:21 AM
SiR Inspired ED7's Avatar
Default B16a: Weird Idle after i hit a dip :-( (Video inside)
car: 88 crx si with b16a
Everything Stock
(i bought the car with the vtec controller so don't even ask why i have it)
hey guys i have a 88 Crx Si and i was driving home last night after coming from a friends house when i suddenly hit this dip (stupid me) well, not my car idles low like about 400rpm video here of hoow my car sounds. i'm thinking i have a cracked header but i'm not sure i have not checked it since it was night time but i will check it today. anyone can give me any idea what it can be?
cliff notes:My normal idle is about 800-900 and i hit a dip now i idle at 400-500
http://s23.yousendit.com/d.asp...SGMNT
Old May 12, 2005 | 09:25 AM
wrXtian's Avatar
Default Re: B16a: Weird Idle after i hit a dip :-( (88 Crx Si)
holy crap 21.1 MB?!?!?!?
Old May 12, 2005 | 03:04 PM
Default Re: B16a: Weird Idle after i hit a dip :-( (D16A6_HF)
anyone? i just checked my header and where the header and the cat connects it's not closed(tightend from the top which means my header got bent where it connects. can that cause my idle to go down since it's leaking air from that part.?
Old May 12, 2005 | 04:56 PM
mar778c's Avatar
Community Builder
Community Influencer
I'm not sure about the header, but I would check my hoses to make sure nothing came apart. Also, check your throttle cable. It may be loose or out of adjustment.
Old May 12, 2005 | 05:06 PM
Default Re: B16a: Weird Idle after i hit a dip :-( (mar778c)
will check that, thanks anyone else? input?
Old May 12, 2005 | 08:56 PM
prkiller's Avatar
Like I said, it's most likely a vacuum line. If everything was fine before the bump, then just check to make sure everything is connected.
Also, check the TB as already mentioned. If everything is fine, just adjust the idle up a bit with the idle screw and leave it be!
Old May 12, 2005 | 09:46 PM
Default Re: B16a: Weird Idle after i hit a dip :-( (prkiller)
i was messing with the vac cables, and it threw me a code for the Cel 3 - MAP
so it's prolly already going out on me, but the check engine light went on then i turned off the car and turned it back on and i got no cel-3 no more...well, ima have to just keep messin with it and like u said ima adjust that idle screw a bit higher thanks guys!
Old May 13, 2005 | 03:07 PM
mar778c's Avatar
Community Builder
I don't think you can't get rid of a code by turning the car on and off. If you check the ecu it will still be blinking. Code 3 is a map sensor. That will affect you idle.
Here's the list of codes:
https://honda-tech.com/zerothread?id=468260
Old May 13, 2005 | 03:58 PM
this is how it went, yes my idle is messed up i idle at 500 ish and i used to idle at 800-900. i tried what that guys had said by turning off my car and turning it back on well, it worked but, the ecu still throws a code 3- MAP. so i may need a new MAP sensor, how much do these usually go for? it's for a b16a keep that in mind
Old May 13, 2005 | 06:49 PM
mar778c's Avatar
Community Builder
The map sensor is on the fire wall. Any map sensor from a 88-95 civic will do. To clear the code, you can disconnect the battery or the ecu.
Old May 13, 2005 | 07:53 PM
wrXtian's Avatar
i have a map sensor i can sell you.. it's not the kind that mounts to the firewall it's the kind that bolts to the throttle body, but it still works.. i had it in my b16a ef for a little while.
Old May 22, 2005 | 11:52 PM
i fixed the problem, guys... it was the stupid fuel filter atleast that's what i replaced and made my car work like a charm like before. well, just wanted to let ya know, lates
Granulatedsugar
Apr 15, 2016 01:19 PM
apbtwhiskey
Mar 20, 2013 09:39 PM
alupso
Mar 4, 2008 02:43 AM
Dat1BVtecN
Oct 3, 2006 01:55 PM
drifter_for_life06
Jul 12, 2005 07:16 PM
