Stiff Clutch Pedal.
Old May 12, 2005 | 06:05 AM
Bizarre's Avatar
Default Stiff Clutch Pedal.
Hey,
I have a 90 Civic with a 1st gen b16 swap. My clutch pedal has become so hard to push down lately, and has been making squeaking noises. It was so stiff, that the actual arm of the clutch pedal from the pressure snapped off. I had to replace the pedal set. Anyways, I was thinking the cause of the stiffness might be the clutch cable.What do you guys think? Or do you think it's something else like a throwout bearing?
Thanks for looking.
Old May 12, 2005 | 06:41 AM
91civicsedan's Avatar
the clutch cable is either froze up or the cable got twisted from the swap
Old May 12, 2005 | 08:12 AM
Bizarre's Avatar
Oh, and another thing, the cable I would order would be from a 90-93 Integra correct?
Old May 12, 2005 | 11:01 AM
Brownjd's Avatar
Default Re: (Bizarre)
you can use the civic cable, just not the one you have now
Old May 12, 2005 | 11:27 AM
Bizarre's Avatar
Default Re: (Brownjd)
Ya I know, but I think I remember reading somewhere that if you use the Integra one, I won't have any shortening to do.
Thanks guys for your help.
Old May 12, 2005 | 03:29 PM
quik89's Avatar
you can use either one, integra or civic.....what i did was just used the civic one and flipped the bracket upside down that holds the cable right above the tranny....where it is tightened...that worked fine..
Old May 12, 2005 | 04:11 PM
TurtleEF3's Avatar
Default Re: Stiff Clutch Pedal. (Bizarre)
My original 17 year old clutch is super stiff and it sometimes makes squeaking noises too. hope my pedal doesn't break off
Old May 13, 2005 | 05:01 AM
Bizarre's Avatar
Default Re: Stiff Clutch Pedal. (EFcivicHB)
Hehe..
I was surprised the pedal went before the cable did.
Once again, thanks for everyones input. The cable was ordered yesterday and will be in today.
Old May 13, 2005 | 07:54 AM
Its me DUB's Avatar
mine does the same thing, but if I loosen the cable, I don't have much pedal pressure (little to none). same problem? twisted up?
Old May 13, 2005 | 09:25 AM
FalkenSiR's Avatar
Default Re: Stiff Clutch Pedal. (doitdub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doitdub &raquo;</TD></TR><TR><TD CLASS="quote">mine does the same thing, but if I loosen the cable, I don't have much pedal pressure (little to none). same problem? twisted up?</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFcivicHB &raquo;</TD></TR><TR><TD CLASS="quote">My original 17 year old clutch is super stiff and it sometimes makes squeaking noises too. hope my pedal doesn't break off </TD></TR></TABLE>
me too
MetallicDa9
Transmission & Drivetrain
Apr 3, 2011 06:23 AM
XplicitzOldSkoolDA
Jun 7, 2008 08:42 PM
Speed_69
Apr 21, 2006 11:00 AM
user 72830283
40
Sep 22, 2005 12:06 PM
