EK sides on EF hatchie???
Old May 12, 2005 | 05:35 AM
sircrxracer's Avatar
Default EK sides on EF hatchie???
I thought I seen it done before Ek side skirts factory on a EF hatch is there any write up's or how too's??? TIA Rob
Old May 12, 2005 | 06:05 AM
OptimusPrimeX's Avatar
Default Re: EK sides on EF hatchie??? (sircrxracer)
yeah.. you can do it. You just have to cut a bit of the EK side-skirt off from the front side portion. I would assume that it would be just as easy as any other Lip. Drill some holes, and your set
But if there's a write up, i dont know.. maybe someone else can point you to it.
Old May 12, 2005 | 08:45 AM
b16std's Avatar
Default Re: EK sides on EF hatchie??? (OptimusPrimeX)
yea i have them on my car now, not hard at all...gotta trim bout 2-3 inches off each side and pretty much the rest lines up...i will see if i can get some pics for you ...
Old May 12, 2005 | 10:30 AM
Default Re: EK sides on EF hatchie??? (b16std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16std &raquo;</TD></TR><TR><TD CLASS="quote">yea i have them on my car now, not hard at all...gotta trim bout 2-3 inches off each side and pretty much the rest lines up...i will see if i can get some pics for you ...</TD></TR></TABLE>
Thanks aaaaaalot if you could do that for me man to you. Rob
Old May 12, 2005 | 11:24 AM
b16std's Avatar
np see what i can do for ya
Old May 13, 2005 | 12:48 AM
smutmonger's Avatar
i would love to see your write up on this one!!!
thanks in advance
Old May 13, 2005 | 04:56 AM
b16std's Avatar
Default Re: (smutmonger)
didnt get those pics yet...but will today...
Old May 13, 2005 | 05:34 AM
Default Re: (b16std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16std &raquo;</TD></TR><TR><TD CLASS="quote">didnt get those pics yet...but will today...</TD></TR></TABLE>
ok cool man I would really like to see whn the doors open. Rob
Old May 13, 2005 | 05:54 AM
b16std's Avatar
Default Re: (sircrxracer)
ok cool yea n/p
Old May 13, 2005 | 06:25 AM
brad 1.cam's Avatar
yea i saw pics of it in my diy/custom lips thread ill get the link for yo! im putting them on my crx
ok im back heres that link:
https://honda-tech.com/zerothread?id=1217880
ok peace! they look sick yo
Old May 13, 2005 | 09:17 PM
bump ^_-
Old May 14, 2005 | 01:20 PM
FalkenSiR's Avatar
Anybody know how much the ek side skirts run for from honda?
Old May 15, 2005 | 03:22 PM
isekiEF9's Avatar
that would be tight we need some pics of it
Old May 17, 2005 | 04:03 AM
any pics yet??? Rob
Old May 17, 2005 | 04:33 AM
HotWheels's Avatar
I've read a similar tech in HCI magazine, where they had to modify the side skirts from a kit that was only available for a hatch, to fit on a EG coupe. If I were going to do it, I would not trim from the ends just cause the fit and finsih would not look as good IMO...
Heres my method of doing it:
1.Measure the length of area where the skirt goes, and figure out how much needs to be removed from the skirt itself.
2.Tape off the area on the inside of the skirt where there is no details to the skirt (like "aero" designs and such), and cut the piece. Give yourself some extra room to play with! You can ALWAYS remove more, but once you take away too much you're stuck with a skirt that's in two pieces and is too short.
3.Once you have check the fit of the two pieces, use a few clamps or a Workmate to hold the two pieces flat and together. Use ABS glue, or if you want to get difficult fibreglass.
4. Prime the entire piece once it has dried and start sanding to make it smooth (you want to hide the area where the two pieces are glued together). keep repeating this until you have to finish you want.
5. Take down to your local body shop and have the color of your car applied to the skirt.
I hope that helps any. Also, I think you asked a great question and I am actually doing the same to my car
Old May 17, 2005 | 07:56 AM
Default Re: (HotWheels)
Yea that's kinda the idea I was thinking I had to do alot of mods to my 99 Si front lip to fit on my CRX but I used duct tape urathane and a heat gun..... I'm sure I can do EK sides on my hatchie....... just though I would ask. Rob
efcrew
Jul 18, 2007 04:25 PM
AllMotaEF9
17
Mar 21, 2007 06:20 PM
Dan-Dillinger
Oct 17, 2005 09:33 AM
eg360B
May 26, 2004 04:20 PM
eg360B
May 25, 2004 11:52 AM
