Best way to remove paint off of an I/C?
Old May 12, 2005 | 05:15 AM
Bimmerman's Avatar
Default Best way to remove paint off of an I/C?
I bought a kit and the i/c has been sprayed black, I want it to be the regular color. What is the best way to remove the paint, or should I just shoot it with some silver?
Old May 12, 2005 | 05:24 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Best way to remove paint off of an I/C? (Bimmerman)
use this
you can get them in kragen's or murray's
or get aircraft remover
Old May 12, 2005 | 05:27 AM
BoostedEG6's Avatar
if its rattle can paint then you can use break cleaner also..
Old May 12, 2005 | 05:39 AM
USDM 4G VTEC's Avatar
get aircraft coating remover
spray it good all over
wait 1.5 minutes
spray with a garden hose and see the whole thing shine!
Old May 12, 2005 | 05:44 AM
Bimmerman's Avatar
Default Re: (USDM 4G VTEC)
cool, i'll pick up some aircraft remover tomorrow.
Old May 12, 2005 | 05:52 AM
MrBui's Avatar
doesnt that stuff eat aluminum?
Old May 12, 2005 | 07:16 AM
Blackack26's Avatar
Default Re: Best way to remove paint off of an I/C? (MrBui)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrBui &raquo;</TD></TR><TR><TD CLASS="quote">doesnt that stuff eat aluminum?</TD></TR></TABLE>
I remember seeing two kinds, stuff that said aluminum safe (more $$) and the other which didn't.
Old May 12, 2005 | 07:44 AM
nerdsports's Avatar
i received a starion i/c once painted in this nasty silver color...
i sprayed it down with aircraft paint remover and it was a PITA to remove all the paint scraps from the fins.
good luck.
[edit:: darn, must have used it wrong [/sarcasm] not sure how wrong you can spray something but ok... ]
Modified by nerdsports at 12:46 PM 5/16/2005
Old May 12, 2005 | 08:14 AM
CRXDrew's Avatar
^ you must have used it wrong. Aircraft remover + hose = clean off any painted surface.
vtec.dc2
Aug 14, 2007 07:41 PM
eg_junior
15
Apr 24, 2007 06:27 AM
rice a roni
Jun 8, 2006 12:59 PM
Tad
Apr 23, 2004 10:09 PM
getfast
24
Nov 27, 2001 06:53 PM
