Turns signals dont work?
Old May 12, 2005 | 05:00 AM
sadangryboi's Avatar
Default Turns signals dont work?
my turn signals stopped working on my 93 eg cx...any ideas??
Old May 12, 2005 | 06:12 AM
North_Texas's Avatar
Default Re: Turns signals dont work? (sadangryboi)
Fuse. Can be other minor things also.
Old May 12, 2005 | 10:27 AM
ok ill check the fuse...but i dont got the cover to see what to check soo i guess ill just go through them all...then if it doesnt work still
what else can i check?
Old May 12, 2005 | 11:06 AM
Default Re: (sadangryboi)
Wiring or check all the fuses for the lighting. Won't take that long so get annoyed with it. I believe it's a fuse but check anyways. Upon a accident my tails went out only worked when braking. My cluster light and corners went out. I changed to four fuses I believe because that **** happened. So moral of the story is check all the lighting fuses. I think they are 10A as well. Hope that helps out a lil'.
H&Co.
Old May 12, 2005 | 12:10 PM
t0ekn3e's Avatar
fuses and they are 10a
ant13
Feb 10, 2014 01:44 PM
UniqueX707
Oct 24, 2011 10:21 AM
Uneekpinoysk8er
Mar 24, 2004 12:41 AM
BrandonClaps
Nov 17, 2002 04:55 PM
