Motor gets too Hot...
Old May 11, 2005 | 10:39 PM
Methane2k2's Avatar
Default Motor gets too Hot...
i was wondering if its normal or my engine fucked up allready..... ive notices recently that my engine hot too quick... i mean very hot and as soon as i open the hood bunch of hot air comes out....any ideas on the problem? or is it just normal
Old May 11, 2005 | 11:42 PM
ForceXVII's Avatar
Default Re: Motor gets too Hot... (Db2_iNtEgRa)
Your thermostatic valve probably stuck closed. Check for coolant leaks.
Old May 11, 2005 | 11:54 PM
Methane2k2's Avatar
Default Re: Motor gets too Hot... (ForceXVII)
yes it does have coolant leaks i have to be putting coolant like every 4 days cus it leaks it all out!!
Old May 11, 2005 | 11:56 PM
Supertramp's Avatar
you have to fix the leaks or it'll always get hot once it loses some water
Old May 12, 2005 | 12:01 AM
egg_baLLa's Avatar
Default Re: Motor gets too Hot... (Supertramp)
yeah check the hoses. i had that problem before. i couldnt not find where it leaked for the life of me. but i know it was leaking from somewhere. so i just flushed the radiator and refilled. problem never came back.
Old May 12, 2005 | 06:11 AM
JustinG60's Avatar
Default Re: Motor gets too Hot... (egg_baLLa)
also may want to check the radiator end caps since they are known to leak...
Old May 14, 2005 | 10:24 AM
Methane2k2's Avatar
Default Re: Motor gets too Hot... (JustinG60)
koo ill check for this thanks peeps.
Old May 14, 2005 | 01:41 PM
ckyguy's Avatar
its possible your waterpump needs to be replaced....that's always fun
Old May 14, 2005 | 01:46 PM
ALMXDUPINTEGRA's Avatar
Use Redline Oil's "Water Wetter" makes the car run about 28degrees cooler
Old May 18, 2005 | 10:53 PM
Methane2k2's Avatar
Default Re: (ALMXDUPINTEGRA)
Old May 18, 2005 | 11:10 PM
no2unenolife's Avatar
try some radiator stop leak
Old May 19, 2005 | 08:08 AM
DavidT or VajT's Avatar
Default Re: (no2unenolife)
If you keep driving around like this, your head may warp due to the intense heat that shouldn't be occurring. Diagnose your problem while your motor is still ok...it may save you a lot of money
Old May 19, 2005 | 06:08 PM
Integra_RS's Avatar
I got a warped head myself. I bought the car & the previous owner had a blown head gasket & a few coolant leaks (which I went to mechanic before i even bought the car & he said it was A ok), so I had Acura fix everything & the bill came to $1010.86, to machine the head, change the head gasket, replace a few hoses thermostat etc.
Old May 26, 2005 | 11:34 PM
Methane2k2's Avatar
Default Re: (Integra_RS)
koo thnx for the info
Old May 27, 2005 | 12:31 AM
iloveboys's Avatar
Default Re: (Db2_iNtEgRa)
is your car overheating? the advices look like they are pointing at an over heating car. from what i read, youre just experiencing heat rising out of your hood. its normal for you to feel heat coming out from your engine bay when you open up your hood. after all, heat rises. if you dont have aheat shield on your header, there is more heat underneath the hood.
Old May 27, 2005 | 12:34 AM
DirtyzGsR_9i6's Avatar
Default Re: (iloveboys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iloveboys &raquo;</TD></TR><TR><TD CLASS="quote">is your car overheating? the advices look like they are pointing at an over heating car. from what i read, youre just experiencing heat rising out of your hood. its normal for you to feel heat coming out from your engine bay when you open up your hood. after all, heat rises. if you dont have aheat shield on your header, there is more heat underneath the hood.</TD></TR></TABLE>
i owned 3 different integras in 4 years and never seen or heard about that once...its probably a leak in your radiator...
Old May 27, 2005 | 12:41 AM
iloveboys's Avatar
Default Re: (DirtyzGsR_9i6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyzGsR_9i6 &raquo;</TD></TR><TR><TD CLASS="quote">
i owned 3 different integras in 4 years and never seen or heard about that once...its probably a leak in your radiator...</TD></TR></TABLE>
Old May 27, 2005 | 07:07 AM
chris23492's Avatar
Details wuld be helpful how hot r u talking ??? Overheating??? or just running hot
Old May 27, 2005 | 08:08 AM
95tegNONVTEC's Avatar
Default Re: (ckyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ckyguy &raquo;</TD></TR><TR><TD CLASS="quote">its possible your waterpump needs to be replaced....that's always fun</TD></TR></TABLE>
yup happened to me n not cheap if you dont do your own wrenchn
if that is it then change timing belt n oil pump while youre at it
Old May 27, 2005 | 08:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife &raquo;</TD></TR><TR><TD CLASS="quote">try some radiator stop leak</TD></TR></TABLE>
to that how bout using MacGyvers method and put raw eggs in it lol Dont tell someone to use that sheet when he could actually have a serious problem like the water pump.
Old May 27, 2005 | 08:53 AM
TEXN3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Use Redline Oil's "Water Wetter" makes the car run about 28degrees cooler</TD></TR></TABLE>
seriously...might be kinda nice when i'm in arizona for the summer. the outside temp tends to be about 30 degrees higher than what the car is normally run in. is this something that is poured into your coolant reservoir?
Old May 27, 2005 | 05:19 PM
Sam92Teg's Avatar
Default Re: (TEXNTEG)
Funny how after all these posts, no one asks what his temp gauge is reading, lol.
Old May 29, 2005 | 11:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEXNTEG &raquo;</TD></TR><TR><TD CLASS="quote">
seriously...might be kinda nice when i'm in arizona for the summer. the outside temp tends to be about 30 degrees higher than what the car is normally run in. is this something that is poured into your coolant reservoir?</TD></TR></TABLE>
Actually you drain out your coolant from the radiator and block. You pour the water wetter in the radiator and fill the remaining with distilled or purified water. It has anticorrosive agents so dont worry about rust.
http://www.redlineoil.com
Theres a demo on it.
Old May 30, 2005 | 12:40 AM
aeon's Avatar
i've been wondering about this also. the other day i was just warming up my motor and it started to get really hot. within 5 minutes the radiator was burning hot and both the top and bottom radiator hose were really hot. ins't the bottom hose suppose to be a little cooler then the top hose? is this normal becaues my brothers b16 motor doesn't do this.
Old May 30, 2005 | 06:39 PM
EnjoyTheRideDC2's Avatar
Default Re: (aeon)
The bottom hose will feel just as hot as the the top hose after the car has warmed up. IMO, I wouldn't pay too much attention to how hot the hoses and radiator feel. The temp gauge is the thing to pay attention to.
