Quarter Mile Times
Old Feb 4, 2002 | 01:27 PM
TT1875's Avatar
Default Quarter Mile Times
What is the record 1/4 mile time for a 4th/5th gen Lude without a motor swap? Im using a Supra term, but with BPU (headers, exhaust, intake...ect) what times would you be looking at then? How good is the handling for a Lude? Sorry for so many questions, but thank you.
R
Old Feb 4, 2002 | 01:48 PM
976's Avatar
976
New User
Default Re: Quarter Mile Times (TT1875)
Someone from hondaprelude.com has almost stock - cai/h/e/vtec controller.
He ran a 14.39 - very good; hardly believable. From the pictures of his car he had added weight too. That time can be slimmed down a lot.
vntperformance (member here) - got 14.52 w/ a good amount of performance upgrades:
AEM Anodized Blue 2 Piece CAIntake
5Zigen "Miracle" Fireball 2.5 Cat-Back Exhaust
STR Anodized Blue Cam Seal
Polished Valve Cover
Accel 300+ Thundervolt Blue Spark Plug Wires
Mallory 682 Race Ignition System
Gutted Cat
Apexi V-AFC
Crower 63422 Billet Stage2 Cams
REV +.5mm Oversize Valves
REV Titanium Retainers
REV Dual Valve Springs
AEM Cam Gears
ERICKS Racing Billet 68mm Throttle Body
Port/Polish Head w/5 Angle Valve Job
Match Port/Polish Intake Manifold
Match Port/Polish DC Sports C/C Header
JDM Type-S 11:1 Pistons w/OEM Rings
Balanced Complete Bottom End & Micro Polished Crank
0.25 Milled Head w/Polished CombChamber
Spoon Sports Metal Head Gasket
Spoon Sports 65º Thermostat
Fidanza Flywheel (Balanced)
A.C.T HA3SS Clutch Kit
http://www.hondaprelude.com/resource...lips.asp?gen=5
Check it out, there is also dyno's if you're into that!
Old Feb 4, 2002 | 01:54 PM
JG Luder's Avatar
I had a mid 13 second N/A car on street tires, just only got a 13.90 run before I did a bunch more stuff, then blew up. never had a chance to get my mid 13 timeslip.
Old Feb 4, 2002 | 02:05 PM
apexii's Avatar
1993 vtec, 14.2-14.1@96mph on slicks. All bolt-ons, minor weight reduction, full leather interior. Never once opened that motor, 145k miles
[edit...........Then the turbo came and it went by-by in 20 mins... ]
[Modified by apexii, 6:06 PM 2/4/2002]
Old Feb 4, 2002 | 02:30 PM
hybridreams's Avatar
Default Re: Quarter Mile Times (w00t!)
Gutted Cat
Apexi V-AFC
AEM Cam Gears
14.5? With all that? That's really, really bad...bas as in not good. Why get the parts if you can't even drive?
Old Feb 4, 2002 | 03:58 PM
TT1875's Avatar
Default Re: Quarter Mile Times (hybridreams)
That is a ton of mods for the time it seems. I guess Im used to a few hundred $$'s making a significant difference in hp and time slips. The Lude seems like a great car despite of that, I guess I need to take a step out of my 2JZGTE world
Old Feb 4, 2002 | 04:22 PM
wutangben's Avatar
basically, a bpu lude will run mid 14's.
Old Feb 5, 2002 | 02:57 AM
vntperformance's Avatar
Actually.,
If you look carefully at my setup, you see where it says 14.52 BEFORE BUILD UP that means before I went into the motor! Which means that when I only had I/H/E/VAFC, that's what that means......... take some time to read before you post. I haven't run the car yet after I went into the motor ie; cams/camgears/pistons/p&p/clutch/flywheel/etc (Awaiting Dyno Tuning & Local Track to Open)!
sheeesh...
vnt
[Modified by vntperformance, 6:59 AM 2/5/2002]
[Modified by vntperformance, 7:00 AM 2/5/2002]
Old Feb 5, 2002 | 05:06 AM
Default Re: Quarter Mile Times (vntperformance)
I don't see where it says BEFORE BUILD UP on that post...but my mistake, what are looking on getting now? I see low, low 13's, possibly even 12's
Old Feb 5, 2002 | 06:41 AM
fierce's Avatar
if you continue to read (tsik tsik) he says
Before 14.53@96.33mph
Now 13.??@??.??mph
so obviously hes hoping for 13's... 12's are unreachable with his mods.
and for my 1/4th, with intake only 14.8
[Modified by fierce, 3:42 PM 2/5/2002]
Old Feb 5, 2002 | 07:05 AM
Greyout's Avatar
Default Re: Quarter Mile Times (fierce)
CAI on an otherwise stock '94 lude
14.6 @ 96
Old Feb 5, 2002 | 08:35 AM
LudeBehavior's Avatar
New User
Default Re: Quarter Mile Times (JDM LUDE)
Damn man if I don't hit 14's I will be pissed. Don't even car if it's high 14's I have a couple mods tho.
Old Feb 5, 2002 | 10:26 AM
apexii's Avatar
Now 13.??@??.??mph
Agreed, and noway are 12's reachable with that setup! You need some serious power(or serious stripping) to shave off another 1.5sec...........
Old Feb 5, 2002 | 10:50 AM
Default Re: Quarter Mile Times (apexii)
On slicks, no back seats, and a good suspension setup, I think a 12.9 is attainable. I/H/E and on front slicks, my friend ran a 14.2 in his 4th gen.
Old Feb 5, 2002 | 10:52 AM
Acutally, looking over the list of mods again...I take back my previous statements...low 13's at best.
Old Feb 5, 2002 | 11:21 AM
apexii's Avatar
You do know that back seats weigh under a pound, right? That's in leather.
Old Feb 5, 2002 | 12:59 PM
No, I didn't know that. I'm not a Prelude person, just flipping through some posts. I realize I'm not in my territory here so I'll keep my trap shut
Old Feb 5, 2002 | 01:16 PM
apexii's Avatar
aaah its cool, it never hurts to give your thoughts on the scenario. I was saying that not to be a d!ck, but to point out that most people, including me at one point, think that the rear seats are a good way to remove weight. Once you're in there, you realize they're nothing but a molded piece of foam!
Old Feb 5, 2002 | 06:30 PM
migo's Avatar
New User
14.1 bolt-ons w/ No internals No NOS
And now I have the internals to get me there............800 more mils to go
Old Feb 5, 2002 | 10:49 PM
wutangben's Avatar
Default Re: Quarter Mile Times (D.specs)
maybe im just not aware of some poo poo, but i just dont believe a 14.1 is possible with boltons. what all do you have done?
Old Feb 6, 2002 | 12:26 AM
BlueShadow's Avatar
I think you're reffering to "ED_CAMDEN" that time could be correct, I believe he lives in Canada where the air is a little colder and denser.
The typical times for Lude owners with similar mods in CA and TX are in the 14.5-14.7 range.
Old Feb 6, 2002 | 06:24 AM
Honda318dx's Avatar
Default Re: Quarter Mile Times (BlueShadow)
My car will probably run a very low 14 now.. With h/i/ no exhaust.. But very gutted, but also has a 100lb rollcage in it..
Old Feb 6, 2002 | 09:40 AM
Default Re: Quarter Mile Times (wutangben)
I'm with you man... poo poo all the way!
vnt
Old Feb 6, 2002 | 10:49 AM
976's Avatar
976
New User
Actually., If you look carefully at my setup, you see where it says 14.52 BEFORE BUILD UP that means before I went into the motor! Which means that when I only had I/H/E/VAFC, that's what that means......... take some time to read before you post. I haven't run the car yet after I went into the motor ie; cams/camgears/pistons/p&p/clutch/flywheel/etc (Awaiting Dyno Tuning & Local Track to Open)!
sheeesh...
vnt
I should have pointed that out. Sorry vnt...
Old Feb 7, 2002 | 11:15 AM
thank u sir!
vnt
