Weird Idle
Old May 11, 2005 | 04:59 PM
ch0's Avatar
ch0
Default Weird Idle
1990 crx si with a b16a. Idle goes down to 500 or little less, almost dies and kicks back up to around 700-800. Then does it again every 5 or so seconds. Whats the problem here. Wont do this when it starts up, only after the car has been driven for a couple minutes.
Modified by ch0 at 11:24 PM 5/11/2005
Old May 11, 2005 | 05:13 PM
Mr_Si-R's Avatar
are you flashing any codes?
Old May 11, 2005 | 05:14 PM
ch0's Avatar
ch0
Default Re: (Mr_Si-R)
Code 23, knock sensor.
Old May 11, 2005 | 05:16 PM
Mr_Si-R's Avatar
http://www.we-todd-did-racing....DE%3D
https://honda-tech.com/zerothread?id=468260
theses links should help you out
Old May 11, 2005 | 05:29 PM
ch0's Avatar
ch0
So what exactly is the knock sensor for? Is this why my idle is weird?
Old May 11, 2005 | 10:23 PM
ch0's Avatar
ch0
bump
Old May 12, 2005 | 01:17 PM
ch0's Avatar
ch0
bump bump bump
Old May 13, 2005 | 08:25 AM
ch0's Avatar
ch0
bump
Old May 13, 2005 | 09:03 AM
AychTwenee2's Avatar
Default Re: (ch0)
The Knock sensor senses any vibration in the block that's not suppose to be there. It shouldn't affect your idle. Mine does that after it warms up, but i have a chipped ECU, and that usually happens with those. Is yours chipped? If not, then the only other thing i can think of is your alternator might be wiggin', i've had that problem too.
Old May 13, 2005 | 11:58 AM
ch0's Avatar
ch0
Default Re: (VeeTekCrx)
Its non chipped pr3.
Civic082382
Oct 23, 2010 05:41 PM
EJeff8
May 3, 2010 05:07 AM
ls19integra95
Jan 15, 2008 02:01 PM
HONDRETTI
Dec 6, 2007 09:31 PM
H23 Power
Apr 21, 2002 10:39 AM
