Crower 402 valve adjustment problem... feeler's gauge wont slip in
Old May 11, 2005 | 04:36 PM
integmester's Avatar
Default Crower 402 valve adjustment problem... feeler's gauge wont slip in
I'm having a problem with the intake side on cylinder one's valve adjustment. I unscrewed(I have all of them unscrewed as much as possible) the bolt as much as possible, but the feeler's gauge wont go through. Timing is set at TDC.
What is causing this to happen?
I didn't have trouble with the exhaust side on cylinder one and not have started on cylinder 2,3,&4
Modified by integmester at 6:02 PM 5/11/2005
Old May 11, 2005 | 05:06 PM
Default Re: Crower 402 valve adjustment problem... feeler's gauge wont slip in (integmester)
Just tried turning clockwise while sticking in the gauge. Did a whole 360 and it still didn't fit through.
Old May 11, 2005 | 08:31 PM
.water's Avatar
did u put gauge filler from middle of head?
Old May 12, 2005 | 08:29 PM
Default Re: Crower 402 valve adjustment problem... feeler's gauge wont slip in (Chris DC2)
what do you mean? i must of have not
Old May 19, 2005 | 10:15 AM
JDM KING's Avatar
bump cuz i have the same problem with my ls...kinda weird. what are you gapping them at?
b20acura
May 27, 2009 11:23 AM
BAYgasDC2
Jun 29, 2007 04:29 PM
straywalker
Jan 30, 2007 07:03 AM
LudeChild
Mar 31, 2005 01:53 PM
