Need Help with Oil pump removal
Old May 11, 2005 | 03:54 PM
NoVALude's Avatar
Default Need Help with Oil pump removal
Alright I finally got the bal. gear off (both of them along with the crank pulley and gear)...and all the bolts are out of the oil pump. I also took all the bolts out of the oil pan and should be ready to remove the oil pump. I do not see anything else holding it in place. Except....how do I get it off? It has sealer and I do not want to pry on anything. Should the oil pump slide off over the crank and bal. shafts? Anyone.....????
Old May 11, 2005 | 05:28 PM
PirateMcFred's Avatar
Default Re: Need Help with Oil pump removal (NoVALude)
You have the right idea. There are tabs on the oil pump that you can get a socket and screwdriver under to pry the thing off. Start at a seam that terminates at a point. You can also use a wood/plastic dowel and a mallet to free up the sealant, just be careful. That HondaBond is tough stuff.
Pirate
Old May 11, 2005 | 05:43 PM
NoVALude's Avatar
Default Re: Need Help with Oil pump removal (PirateMcFred)
Thanks Pirate....I started to pry at the top with a rag between the screwdriver and the pump. It started to come apart and I can fit the screwdriver in a few places. Will continue onward tomorrow and let you know how it goes. Once I get the pump off, then I pry off the oil pan, I can really get to work.
Old May 12, 2005 | 04:28 AM
um the oil pan bolts to the oil pump... you might want to remove the pan first.
Pirate
Old May 12, 2005 | 03:06 PM
NoVALude's Avatar
Ok, got the oil pan off and got the oil pump off too.....I started taking the bearing bridge off ( in the sequence mentioned in the service manual) and got all done except for the last bolt.....breaker bar slipped and I think it is about stripped.....now what? I saw this tool at Advance auto that is meant for stripped bolts/nuts...guess I will have to try that, unless anyone has a good idea (besides torching it) to get this last bolt out so I can take the bearing bridge off and get to the crank finally.....
LobeSex
Oct 6, 2009 01:24 AM
crazyslowhatch
Oct 17, 2004 10:04 PM
NSTY Z33
Aug 4, 2004 10:55 PM
Mefain
May 16, 2003 09:02 AM
