HELP! GSR Exhuast Piping Length VS. Type R
I have a GSR, and I want to install a TYPE R cat back system. I know the length is off, so I was wondering if anyone know the ball park of how many inches i need to extend the end of the stock gsr cat (i will also change the end from a 2.25 to a 2.5 so it will bolt up to the exhaust b pipe) for comestic purpose only i will keep the stock gsr header and cat, i dont want to run test pipe cuz it will be way too loud for so cali!
Thx for the help!
Thx for the help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transport »</TD></TR><TR><TD CLASS="quote">wow! ok thx, thats including the flange on right? so flange extended 4.5</TD></TR></TABLE>
The length is approximate. Make sure you measure before extending the b-pipe.
timmy8151 is correct, the exact length that needs to be added to fit an USDM ITR exhaust on a '94-'99 GS-R is 4.5". I did this a few years ago for installation on my '94 GS-R (see picture below). I had the 1.75" 3-bolt cat flange cut off and had a 2.5" 3-bolt cat flange welded on. I did this so that I could later bolt up (which I just did 2 weeks ago) a JDM ITR 4-1 header (which has a 2.5" collector) and a 2.5" (inlet and outlet) hi-flow cat.
Let me know if you have any questions.
for larger image cut and paste link: http://www.imagestation.com/pi...g.jpg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transport »</TD></TR><TR><TD CLASS="quote">94
at least its the beast motor year and obd1 but i wish it was 01 now so it can bolt up</TD></TR></TABLE>
Excuse this idiot question, but what's special about 94 being a "beast motor year"? What about that year engine made it a beast motor?
at least its the beast motor year and obd1 but i wish it was 01 now so it can bolt up</TD></TR></TABLE>Excuse this idiot question, but what's special about 94 being a "beast motor year"? What about that year engine made it a beast motor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThePro »</TD></TR><TR><TD CLASS="quote">
Excuse this idiot question, but what's special about 94 being a "beast motor year"? What about that year engine made it a beast motor?</TD></TR></TABLE>
if im correct 94/95 gsr motors are normally stronger then some later year gsr motors...
thx for the pic and help guys!
thx for the pic and help guys!</TD></TR></TABLE>
you're killin me! LOL!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transport »</TD></TR><TR><TD CLASS="quote">try comparing obd1 restrictions to obd2, its logic</TD></TR></TABLE>
it's debatable i think. i run the same quarter mile times as most obd1 gsr's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transport »</TD></TR><TR><TD CLASS="quote">if im correct 94/95 gsr motors are normally stronger then some later year gsr motors...</TD></TR></TABLE>
Thats bullshit. Even if it were true those motors have so many miles on them by now they'd be worn and mild mannered by comparison.
yep! im talking about stock to stock miles to miles comparision man...everyone nows obd1 motors are faster then their obd2 motors unless the obd2 motors have upgraded oem parts...its just logically, less restrictions, more power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Transport »</TD></TR><TR><TD CLASS="quote">yep! im talking about stock to stock miles to miles comparision man...everyone nows obd1 motors are faster then their obd2 motors unless the obd2 motors have upgraded oem parts...its just logically, less restrictions, more power</TD></TR></TABLE>
I always knew this, but I thought it was really only restricted in the ecu? Correct me if I am wrong, but besides this what other restrictions do the obd2 motors suffer?
From my understanding as well, obd1 motors respond better to aftermarket parts then obd2 motors, but then again I thoght that was all computer oriented and once changed or chipped, corrected the problem.
the itr exhaust is not crush bent so it keeps its 2.25 inch diameter at the bends. Also the gsr exhaust is smaller in diameter. I believe acura quoted the itr exhaust at flow 30% better than the lower model integras whcih share the same exhaust.
The only drawback is it has a bottleneck where it connects to the cat and the muffler is chambered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">the itr exhaust is not crush bent so it keeps its 2.25 inch diameter at the bends. Also the gsr exhaust is smaller in diameter. I believe acura quoted the itr exhaust at flow 30% better than the lower model integras whcih share the same exhaust.
The only drawback is it has a bottleneck where it connects to the cat and the muffler is chambered.</TD></TR></TABLE>
oh, i was thinking he was getting an aftermarket one. nevermind.
IIRC, the 30% flow increase is with the whole exhaust system; header,cat, catback
I have one on my 00 gsr and it is the exact same size as my stock unit. No black stuff on the bumper.
30% for the entire system? Maybe, but I thought it was just the b pipe and muffler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackSage »</TD></TR><TR><TD CLASS="quote">30% for the entire system? Maybe, but I thought it was just the b pipe and muffler
</TD></TR></TABLE>the header also has a different design than the gsr's, so it can account for better flow (in addition to the larger piping and better flowing muffler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dFreezy »</TD></TR><TR><TD CLASS="quote">the header also has a different design than the gsr's, so it can account for better flow (in addition to the larger piping and better flowing muffler)</TD></TR></TABLE>
increase flow in essence will give you gains in high end, but then you have to give up some low ends...correct?
