EGR valve
Lucky number 13.
First thing I would do is buy yourself a repair guide (chiltons, haynes, helms etc) this will save you A LOT of time and will ease the repair process on most applications.
edit: according to your other post it sounds like your code might be caused by poor egr flow...I would try cleaning out the egr ports before you replace the egr...just a suggestion.
http://www.cb7tuner.com/vbb/showthread.php?t=2495 this write up is on a 4th gen and a 5th gen but the engine/process should be the exact same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">... according to your other post it sounds like your code might be caused by poor egr flow...</TD></TR></TABLE>Yes.
Your code P0401 is for not enough EGR flow rate. There's other codes (P1491 & P1498) for problems with the valve so don't waste your money on a new valve just yet.
Doug Winsor
Aug 26, 2015 12:40 PM
hollywood28601
Dec 27, 2010 11:09 AM
