Suspension & Brakes Theory, alignment, spring rates....
clanking noise coming from my suspension
Old May 11, 2005 | 12:48 PM
eMpAtHy's Avatar
Default clanking noise coming from my suspension
it sounds like the spring or something is loose. when the car is jacked up and the wheels are off the ground, there is freeplay on the coilover and the spring on the passanger side. a lot of it too. i can move it up/down an inch or 2. on the driver side, the movement is limited. the springs/coilovers only move about .5 of an inch or less. would that freeplay make clanking sounds when i drive? it only happens when i ride on bumpy roads or something that requires my shocks/springs to do something. if so, what would be the problem with it. am i missing a bushing or something?
Old May 12, 2005 | 12:38 PM
Rob.'s Avatar
Default Re: clanking noise coming from my suspension (eMpAtHy)
what car you drive ? how low is your car ?
could be you're bottoming out your shock...
could be that your upper control arm is hitting on the top of the fender....
could be a lower susoension component rubbing against something...
chacabaca
Jul 12, 2010 09:59 AM
dtarvin
Suspension & Brakes
Apr 8, 2009 12:06 PM
JCritt
Jul 20, 2005 07:52 PM
TheBlackCrx
Oct 5, 2003 04:37 PM
born2speed
Jul 1, 2002 01:02 PM
