85-87 HF brake drums finned and aluminum
Old May 11, 2005 | 12:11 PM
Tyson's Avatar
Default 85-87 HF brake drums finned and aluminum
just sharing what the 85-87 HF drums look like. direct replacement for 88-91 drums. obviously distinguished by the fins, better heat dissapation (which i dont see why it needs) but incredibly lighter because theyre made of aluminum, not steel. the brake lining is still steel however.
btw, the drums on the insight are nearly the same as these.
Modified by Tyson at 1:21 PM 5/11/2005
Old May 11, 2005 | 01:07 PM
Outsane's Avatar
Default Re: 85-87 HF brake drums finned and aluminum (Tyson)
Nice work Tyson..
I only know of Two 2nd gens with this swap in drums..
I can't stand working on drums..
Old May 11, 2005 | 01:33 PM
fortynineR's Avatar
Default Re: 85-87 HF brake drums finned and aluminum (Outsane)
im actually doing this set up on my crx.. i have a set 92 eg rear drums.. i had to remove the spot welded inner ring on the backing plate in order to make it work.. i'll try and post pics up later... as far as weight goes.. its 7 lbs for the steel drums and 3 lbs for the aluminium drum.. if you do the math.. thats a total of 8 lbs less rotating mass...
Old May 11, 2005 | 01:59 PM
CRXDrew's Avatar
I remember it being hard to find these. Like... 2 years ago. Polished AL would look cool
Old May 11, 2005 | 02:49 PM
Tyson's Avatar
Default Re: (CRXDrew)
yeah, ive seen em polished to bare aluminum. it does look nice. but i gotta get take them off and get them turned. been driving these past two days and theyre rubbing badly. i think ill just strip and paint them black again.
honestly, this is pretty much a cosmetic add on. the less weight really is not affecting my ride. its just a lot nice to see through my wheels than normal drums.
Old May 11, 2005 | 02:55 PM
HumanResource's Avatar
Most HF's I see have replacement Steel units in the junkyard
Thanks for the pic
Now I know what to look for
HEY TYSON!
can i lick your wheels?!
Old May 11, 2005 | 03:35 PM
goforbroke's Avatar
MEAT PATTY
Default Re: 85-87 HF brake drums finned and aluminum (HumanResource)
Grrrr I need those drums for my SM civic. So upgrade though.
Do they still sell these in like autozone, pep boys, ect....?
Old May 11, 2005 | 03:46 PM
Tyson's Avatar
Default Re: 85-87 HF brake drums finned and aluminum (goforbroke)
we discussed how to find them in this thread.
https://honda-tech.com/zerothread?id=1103152
basically, napa shows them in the online catalog, unsure if they can have them. but you can also buy them from the dealer now as they are made for the insight as well. but keep in mind, they are much more expensive than normal drums. i got these from the junkyard...
Old May 12, 2005 | 10:34 AM
goforbroke's Avatar
MEAT PATTY
So they are also on the insight? They bolt up just like the HF drums would?
Old May 12, 2005 | 10:54 AM
crxgator's Avatar
doesnt aluminum heat up faster than steel? maybe thats the reasoning for the fins?
Old May 12, 2005 | 11:04 AM
Sobe_Death's Avatar
you can buy them from Advance/Kragen/Discount/whatever for $95 brand new...
http://www.partsamerica.com/Pr...set=A
Jaker
37
Apr 4, 2016 11:37 PM
EFB16ACRX
Jan 19, 2005 10:21 AM
b16crx0062004
Aug 27, 2004 10:18 PM
EFing8
Feb 5, 2003 05:14 PM
allmotorEG-SI
Mar 31, 2002 05:17 PM
