Gear Switch Stutter
Old May 11, 2005 | 12:10 PM
bonZai's Avatar
Default Gear Switch Stutter
On an auto tranny.. when i accelerate.. and when its changing gears it kinda skips a lil which leaves the car to do a little stuttering shake... and it does it here and there..but lately its been doing it a lot..
Modified by bonZai at 1:32 PM 5/11/2005
Old May 11, 2005 | 05:10 PM
bonZai's Avatar
Default Re: Gear Switch Stutter (bonZai)
bump
Old May 11, 2005 | 05:28 PM
Bcuz's Avatar
Check your trans fluid, it might be low, thats the best case senario. Do you have any DTC's (diagnostic trouble codes)? It could also be your transmission range switch, it's on the side of your trans. It's covered by a black case, remove the case, and there is your range switch. I fyou have codes, it might even be as simple as a pressure switch. Sorry, I know it's alot to take in, but thats the way transmissions are. Good luck. (Keep posting)
Old May 14, 2005 | 07:30 AM
bonZai's Avatar
Default Re: Gear Switch Stutter (Bcuz)
honda said my tranny fluid is slightly burnt
Alexie
Sep 30, 2018 12:16 PM
DEZn00ts
12
Nov 6, 2015 06:46 PM
miked198729
Oct 27, 2014 06:14 PM
dcarpe3
Honda Civic (2001 - 2005)
Jul 2, 2014 07:15 PM
Raven2201
Jul 3, 2013 05:36 AM
