Thermostat ?
Old May 11, 2005 | 12:00 PM
BoostNEF's Avatar
Default Thermostat ?
I have a feeling my thermostat went out....the car heats up right away even after filling up the rad. I felt my bottom rad hose and its some what cold compared to the top one the top one is really hot, could this mean the thermostat is not working properly?
Old May 11, 2005 | 12:24 PM
coot_er's Avatar
Default Re: Thermostat ? (BoostNEF)
sounds like its either your thermostat or waterpump. hopefully its just the thermostat
Old May 11, 2005 | 12:31 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: Thermostat ? (coot_er)
is the coolant overflow reservoir filling up? is the upper radiator hose swelling?
Old May 11, 2005 | 01:05 PM
Outsane's Avatar
Default Re: Thermostat ? (BrokeAssPinoy)
could be... replace it with a failsafe thermostat
Old May 11, 2005 | 01:29 PM
CRXDrew's Avatar
hmm.. when my thermostat went out that car wouldn't warm up... not the opposite. Might aswell replace it. Cheap insurance in the future.
Old May 11, 2005 | 03:52 PM
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. when my thermostat went out that car wouldn't warm up... not the opposite. Might aswell replace it. Cheap insurance in the future.</TD></TR></TABLE>
That's because yours was stuck open = overcooling, his is stuck closed, coolant can't get through, thus overheating
Old May 12, 2005 | 10:34 AM
ben_eg6's Avatar
Default Re: (BrokeAssPinoy)
you can test it see if it's working or not
1. remove the Radiator pressure cap from a cool Radiator
2. start the engine, let it warm up and watch the surface of the coolant
3. when the coolant begin to flow, this indicates the thermostat has started to open, if the coolant does not begin to flow, your thermostat is closed (stucked)
4. if the engine is cold and coolant circulates, this indicates the thermostat is stuck open and must be replace.
Old May 14, 2005 | 01:18 AM
BoostNEF's Avatar
yes the upper one is swelling
dlstech
16
Dec 12, 2012 03:04 AM
aziaticvang
Jan 17, 2008 06:32 PM
soon2bdropped
Apr 6, 2007 11:34 AM
snowblind7x
Feb 21, 2007 08:58 PM
importfanatic17
Jan 4, 2007 09:14 PM
