Bad idea to turbo a high mileage D16?
Old May 11, 2005 | 10:51 AM
WhiteSiDan's Avatar
Default Bad idea to turbo a high mileage D16?
I have a 94 si with about 150k...have recently replaced water pump and all related parts as well as a full tune up...runs strong, but transmission might be on its way out. What should I do turbo/tranny or swap?
Old May 11, 2005 | 11:00 AM
DRIVENRacing's Avatar
Default Re: Bad idea to turbo a high mileage D16? (WhiteSiDan)
good idea boost the hell out of it!
Old May 11, 2005 | 11:06 AM
boostin1cam's Avatar
Default Re: Bad idea to turbo a high mileage D16? (adSPEED)
Hey man i'm in Albemarle, NC and have a sohc non-vtec turbo, adSPEED you ever ran your car at The Rock? just wondering..
Old May 11, 2005 | 11:10 AM
EKhothatch's Avatar
Default Re: Bad idea to turbo a high mileage D16? (93civcoupe)
I boosted mine with 118K on it. It run great but went because it wasn't tuned. It was just running the blue box. It would of lasted a whole lot longer if it'd had been tuned.
Old May 12, 2005 | 05:25 AM
wisjdmhonda's Avatar
Default Re: Bad idea to turbo a high mileage D16? (EKhothatch)
boost it i had 210,000 miles on mine when i did. It ran strong and never blew.
Old May 12, 2005 | 06:33 AM
RemerLex11's Avatar
Default Re: Bad idea to turbo a high mileage D16? (wisjdmhonda)
it'll be fine especially if you build the engine, and tuning will be key so spend good money on that
Old May 12, 2005 | 12:02 PM
redzcstandardhatch's Avatar
something different
if the trans is "going" try replacing the fluid in it, and if that doesnt fix it, have a backup trans, but honda engines can handle boost if they are old but running well.
i have an over-100,000 mile engine being boosted daily. tuning is the key. make sure its got a good partial throttle tune, and a safe but not completely extreme boost tune.
Old May 12, 2005 | 05:40 PM
ginoboy1978's Avatar
Default Re: (redzcstandardhatch)
i have a d16y8 with 195000kms on it.......just got is turbo'd 2 wks ago.......runs perfect. It's all about the tune.
DAN
Old May 12, 2005 | 05:41 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (ginoboy1978)
My buddy is running the AFC hack 180k on the stock D15 and runs strong.... Its all about the tunning, wideband 02s are the bomb!
Old May 12, 2005 | 06:46 PM
SOHCmaster's Avatar
Personally I would do a full leak down to see how sound it was, but if you blow it Im sure you can find another D series for $500-800 from someone.
Old May 12, 2005 | 11:59 PM
WhiteSiDan's Avatar
thanks for the info everyone! i plan on going with the edelbrock turbo kit...any feedback?
Old May 13, 2005 | 01:40 AM
Tdemsko's Avatar
Default Re: (PK SPEED)
some times you can even find them d16 in my area for $300 do it and don't look back
-Thomas
Old May 13, 2005 | 06:05 AM
99lspwr's Avatar
Default Re: (Tdemsko)
Boost the living **** out of that old d16, I am doing it now with 180k + and its taking it like the ***** that it is.!!!!!Just remember to fill the oil and check the gas!!!!lol
Old May 13, 2005 | 07:37 AM
92BlackSi's Avatar
i think it is a great idea!! That way you can tune the bitch and **** using the old motor and in the case that something goes wrong you blow the old motor.
In the meantime, build a better motor. Learning at the cost of the old motor is worth it IMHO.
92integraVTECgsr
Sep 17, 2005 10:13 PM
2gteg93
Feb 9, 2005 12:52 PM
allmotorEG-SI
Dec 18, 2003 07:11 PM
DLB1994
Mar 19, 2002 03:34 PM
