Spark Plugs Help
Is it just me or its hella hard to get to the spark plugs......I want to take them out and check the gap and see if its clean. But the problem is I cant seem to get them out....What are the nut sizing and tools should I use. I've been getting crappy gas milage like 20mpg in the city could that be because of the plugs?Can you guys help out this noob?
use a socket wrench with an extension and either a long 5/8" socket or a sparkplug socket (5/8 with a little rubber piece inside).
To get the plugs out once they are loosened, you can use some 5/16 inch vacuum hose or just use the spark plug boot to grab the tip and pull it out.
This is for an NSX, but I am linking it because it has pictures of what a sparkplug socket and what length extension you would need.
http://www.danoland.com/nsxgar...g.htm
I hate everything
When you do go to take them out, make sure your engine is nice and cool, a thick piece of metal would be a nightmare to that warm aluminum head.
I managed to get the spark plugs out and yea.....i'm gonna buy some new tools.....cuz it was a pain ......at one point I thought my socket was stuck in the spark plug chamber because the rubber peice inside the socket was stuck to the plug. After 5 minutes I was able to get it out. I checked the gap and everything is ok.....I think its because of my crazy driving cuz i drive for pizza hut....I always floor it
kragen and autozone sell those cheap T top spark plug wrench. They are like $3-$4. If you can't open with that by hand, put a water pipe on one end as a leverage, always work for me.
Layziebtnh055
Apr 8, 2004 02:41 PM
Flux
Jul 30, 2002 06:25 AM
