Got a victor x maniofld what did yurs come with ?? Mine isn't complete + any install woes?
I received it today and when i opened the bag was ripped open and the fittings were all through the box . It did not come with the Throttle body gasket or the studs to mount the throttle body , should it have? Also where do i get additional 1/8" npt fittings and plugs at ?
Are there any install problems i should know about before attempting to install , this is for a gsr engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsiperf »</TD></TR><TR><TD CLASS="quote">I received it today and when i opened the bag was ripped open and the fittings were all through the box . It did not come with the Throttle body gasket or the studs to mount the throttle body , should it have? Also where do i get additional 1/8" npt fittings and plugs at ?
Are there any install problems i should know about before attempting to install , this is for a gsr engine.</TD></TR></TABLE>
you should have gotten a throttle body gasket. second you use all you studs from your gsr manifold. you can take them out by using 2 nuts together and take the stud out like that. third you should have gotten trhe npt plugs i did, go to your local hardware store i have seen them in home depot too, just take ur manifold and find the right one. as for install you wont be able to use idle air control valve i think it is but other than that its all cool, you will be going to the hardware store alot to get fittings so buy them now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 »</TD></TR><TR><TD CLASS="quote">
as for install you wont be able to use idle air control valve </TD></TR></TABLE>
sorry but, this is wrong.
all of your factory sensors bolt onto the edelbrock intake mani.
i wanst able to use mine there was no port so your wrong maybe it differs on manifolds which have different heads
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift2004 »</TD></TR><TR><TD CLASS="quote">i wanst able to use mine there was no port so your wrong maybe it differs on manifolds which have different heads</TD></TR></TABLE>
im not about to start an argument with some NOOB.
i know for a fact that the Factory IACV bolts onto the back of the manifold.
dont tell me something that i "supposedly dont know"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">
my bad i got confuse with the part yeah you are right but i meant to say the fast idle valve because their are no ports in the side of the manifold where the throttle body is at
i got a b18b head
</TD></TR></TABLE>my bad i got confuse with the part yeah you are right but i meant to say the fast idle valve because their are no ports in the side of the manifold where the throttle body is at
i got a b18b head
yea, i seen your old posts..
thats the Fast Idle Thermo Valve. it will open and close depending on coolant temp.. its like a small thermostat, and will allow differant amounts of air into the manifold, depending on coolant temp.
btw. throw that thing in the trash... it cause's way to many idle problems.
yeah it will only idle like at 1.5 k now well thats what it does in my car then it drops when it gets hot
So 100% for sure i need to reuse my studs ? There isn't some certain size set of bolts i can just at somewhere?
The fast idle thermo valve is attached from the bottom of the throttle body not on the intake manifold. Some cars have FITV and some don't. Depend on what year your car is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 »</TD></TR><TR><TD CLASS="quote">The fast idle thermo valve is attached from the bottom of the throttle body not on the intake manifold. Some cars have FITV and some don't. Depend on what year your car is. </TD></TR></TABLE>
incorrect, certain models has the FITV attached to the intake manifold, mostly JDM. My first gen JDM b16a manifold had the valve bolted to the maniold not the throttle body. I ditched it easily when i got my victor X
fast idle valve is on bottom of throttle body and idle air control is on back on intake manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg »</TD></TR><TR><TD CLASS="quote">fast idle valve is on bottom of throttle body and idle air control is on back on intake manifold</TD></TR></TABLE>
but i have a b16a manifold that has the FAST IDLE THERMO VALVE attached to the manifold right under the TB. all first gen JDM b16a were that way, i can prove it with pictures if you REALLY wanna argue. I know the idle control valve is on the back side as well.
