What's that noise comin from my engine?
Old May 11, 2005 | 09:53 AM
ETR's Avatar
ETR
Default What's that noise comin from my engine?
What's up everyone...I need some troubleshooting help for this problem I have.
Everytime I turn right I hear a rubbing sound coming from my engine. It happens only when I gas the car and turn to the right. I'm sure that it's not the tires rubbing because it never rubbed before.
Things I changed before I started to hear the noise:
1. Clutch
2. Resurface rotors & change brake pads
Any ideas?
Old May 11, 2005 | 09:54 AM
yoshi234's Avatar
I shoot brides
Default Re: What's that noise comin from my engine? (ETR)
could be the axles?
Old May 11, 2005 | 09:57 AM
Bbasso's Avatar
Sounds kinda like a cat(meow) ?
Old May 11, 2005 | 09:58 AM
ETR's Avatar
ETR
Default Re: What's that noise comin from my engine? (yoshi234)
Could be... What could be wrong with them?
Old May 11, 2005 | 10:01 AM
nightrider's Avatar
is it a scraping sound like metal on metal? if so, possibly may be related to power steering problems.
Old May 11, 2005 | 10:10 AM
ETR's Avatar
ETR
Default Re: What's that noise comin from my engine? (nightrider)
No it's not a high pitch metal rubbing noise. Sounds like a winding, deeper in pitch noise.
Old May 11, 2005 | 12:39 PM
citrus3000psi's Avatar
where is the noise coming from? the front right tire? How fast do you have to be going? Is it when the wheel is cranked all the way or partially? Take the wheel off and look for signs of rubbing thats what I would do first.
Old May 11, 2005 | 05:59 PM
1999all_motoR_teg's Avatar
Default Re: (citrus3000psi)
You just had the brakes done and then the noise started??? My guess would be the backing plate.
Old May 11, 2005 | 08:06 PM
migs's Avatar
Default Re: (1999all_motoR_teg)
If it was your backing plate, it would be constant. The backing plate turns with the entire suspension assembly.
My guess is wheel bearing. I guess that based off the conditions you hear it.
Old May 12, 2005 | 02:18 AM
watty's Avatar
Hi. My ITR makes similar noises- I have recently had a new clutch; installing the new clutch (removing driveshafts etc) disturbed the driveshaft bearing causing it to 'squeek' due to lack of lubrication. After a week or two I got more noises like wearing/grinding noise at full lock, but now does it when i turn slightly!! So this could be similar problem !?
Ime having a new bearing fitted today so hopefully this will fix the problem
Old May 12, 2005 | 02:50 AM
Reid's Avatar
Global Moderator
Who installed the clutch?
I'm guessing one of the axles wasn't installed properly.
Old May 12, 2005 | 05:12 AM
watty's Avatar
Default Re: What's that noise comin from my engine? (Reid)
a local racing team installed my clutch, they know what theyre doin so would have thought it be ok! Ime waiting for another part now so should have the car back tomorrow and hope its ok!
Old May 12, 2005 | 12:03 PM
ETR's Avatar
ETR
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">where is the noise coming from? the front right tire? How fast do you have to be going? Is it when the wheel is cranked all the way or partially? Take the wheel off and look for signs of rubbing thats what I would do first.
The noise sounds like its coming from the right side. It only makes a noise when I'm going very slow like 5mph and about at 45 degree turn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">If it was your backing plate, it would be constant. The backing plate turns with the entire suspension assembly.
My guess is wheel bearing. I guess that based off the conditions you hear it. </TD></TR></TABLE>
Yeah I think it could be my wheel bearing. I'm starting to hear a lot of road noise. But why would it only make a noise when I turn?
Old May 12, 2005 | 02:05 PM
Default Re: (migs)
That is not true at all I've had many customers that heard the noise only when turning or going over a bump and lo and behold it was the backing plate.
Old May 12, 2005 | 02:20 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Check ur dust sheilds yo, they possibly are rubbing on rotors
Old May 14, 2005 | 10:43 PM
migs's Avatar
Default Re: (ETR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">Check ur dust sheilds yo, they possibly are rubbing on rotors </TD></TR></TABLE>
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ETR &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I think it could be my wheel bearing. I'm starting to hear a lot of road noise. But why would it only make a noise when I turn?</TD></TR></TABLE>
Now were getting somewhere. What kind of tires do you have? How long have you had them? What is the condition? Have you had an alignment done recently?
Forrest04
Honda CR-V & Element
Apr 16, 2014 11:50 AM
D7_62
11
Dec 12, 2010 07:22 PM
bpetruzzo
11
Aug 20, 2005 02:54 PM
jujubee
Apr 21, 2002 07:06 AM
