crx rear disc swap.
Old May 11, 2005 | 09:05 AM
type Gendy's Avatar
Default crx rear disc swap.
I've got a 91 crx and i'm throwing a da rear disc swap on it today. I read that the da e brake cables are too long on a crx and to just use the stock ones. Does that sound accurate with anybody who has done this?
Old May 11, 2005 | 09:14 AM
DocSean's Avatar
I know you CAN use the 90-91 crx si e brake cables....but I'm not sure about the stock ones.
Old May 11, 2005 | 09:26 AM
SiR Inspired ED7's Avatar
Default Re: crx rear disc swap. (type Gendy)
i doubt that you can use the stock ones if they're not the si cables... you can use the DA ones, but that's if you creatively route em. That's what i'v been reading on Honda-Tech
Old May 11, 2005 | 09:30 AM
type Gendy's Avatar
Default Re: crx rear disc swap. (88 Crx Si)
so u think the dx cables are way shorter than the si?
I dont think so, figure both go to the same location...i think its just based on chasis, not model
Old May 11, 2005 | 10:47 AM
APEX CRX's Avatar
if your car is a DX and had drums you can't use the old e-brake cables. doesn't matter about length
Old May 11, 2005 | 11:00 AM
EL Vap133's Avatar
You have to use rear disc brake, e-brake cables.
Old May 11, 2005 | 11:01 AM
Outsane's Avatar
Default Re: crx rear disc swap. (APEX CRX)
I believe the ends are different on the drum vs the disk cables
Old May 11, 2005 | 11:31 AM
type Gendy's Avatar
Default Re: crx rear disc swap. (Outsane)
sweet, thanks guys
da cables it is
Old May 11, 2005 | 06:03 PM
Mag00n's Avatar
Just leave it in gear like me TYPE g3nd\|
Old May 11, 2005 | 08:31 PM
EFoneateSI's Avatar
Default Re: crx rear disc swap. (Mag00n)
exactly what i do, kinda had a hell of a time trying to get the si cables on mine to match up with the tegs so i cut the damn things and now they drag. But line lock is cool
Old May 12, 2005 | 05:31 AM
type Gendy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">Just leave it in gear like me TYPE g3nd\| </TD></TR></TABLE>
Then i cant do 180 turn arounds when i see somebody i wanna go race!111!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFoneateSI &raquo;</TD></TR><TR><TD CLASS="quote">exactly what i do, kinda had a hell of a time trying to get the si cables on mine to match up with the tegs so i cut the damn things and now they drag. But line lock is cool </TD></TR></TABLE>
I dont understnad this? You have a 91si? But disc cables werent long(?) enough to meet da hubs? So u just cut them and didnt take them out?
Whats line lock?
Old May 13, 2005 | 04:09 AM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy &raquo;</TD></TR><TR><TD CLASS="quote">sweet, thanks guys
da cables it is </TD></TR></TABLE>
yes just route the cables through the opposite holes that lead into the cab of the car. In other words route the dirverside cable through the passengerside hole and the passengerside vice-versa. That'll take up about another 2" if that. But I did it, and the DA e-brake cables have been working fine for me!
Old May 13, 2005 | 05:33 AM
type Gendy's Avatar
Default Re: crx rear disc swap. (Ox5647)
awesome...good advice bro, thanks
ZCHondaCRX91
Dec 4, 2011 03:03 AM
bradennicely
Oct 12, 2009 06:10 PM
sohcvtec91hatch
31
Jan 4, 2007 02:16 PM
jb0705
May 16, 2006 11:00 AM
TheHatchHog
Aug 24, 2003 06:41 AM
