power window swtich problem
My power window swtich on the right side works only after pushing it a few times. I think the connection is bad on the swtich. Is it something that i could fix or need to buy a new one?
you might be able to fix it. you will need to take the switch out of the handle. I had a similar problem on my old 92 hatch. you can clean it off but it usually ends up happening again.
