need help with mounts
i have installed a 96 vtec motor and gear box in a 90 body, but is having trouble lining up the motor and body. the crankshaft is rubbing on the chassis, i think the tranny mount is no the right one, i am using the mount from the 96 model, anyone can help, please do. thank you
If I am correct you need to use the mounts from your Accord, the 5th gen uses the Prelude mount but on the driver's side. So try swapping them out and seeing if that works.
swiftstyles
Nov 19, 2003 04:58 PM
