turbo z6, what size bfg drag radials?
Old May 10, 2005 | 07:26 PM
PA MATT's Avatar
Default turbo z6, what size bfg drag radials?
Hey, i have a stock d16z6 with the greddy turbo kit on 8 psi(around 180-190 whp)
I'm pretty set on getting BFG G-force drag radials. I have some 91 ls wheels(14x6.5) and some 15x8 american racing wheels(got em really cheap). What rim would be better?the lighter one? What size tire should i be running?I was thinking 24 inch diameter would be nice. I used a tire calculator and came up with the following diameters:
205/50/14=22.07
215/60/14=24.16
205/50/15=23.07
225/50/15=23.86
What does everybody suggest for me?
Old May 11, 2005 | 02:20 AM
Timmay's Avatar
Default Re: turbo z6, what size bfg drag radials? (PA MATT)
205/50/15 is a good way to go
Old May 11, 2005 | 03:26 AM
DIFFUT'S INC.'s Avatar
Default Re: turbo z6, what size bfg drag radials? (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay &raquo;</TD></TR><TR><TD CLASS="quote">205/50/15 is a good way to go</TD></TR></TABLE>
yup yup
Old May 11, 2005 | 04:44 AM
PA MATT's Avatar
Default Re: turbo z6, what size bfg drag radials? (DIFFUT'S INC.)
okay, with a good tune and on 10-11 psi i plan on having around 200whp, would a 23 inch diameter tire still be sufficient?I'm not really sure what those 15's weigh either, so I dont know if it'd be a good idea to use them. thanks for the help
Old May 11, 2005 | 05:16 AM
PA MATT's Avatar
I found the 15x8 wheels weigh about 18 lbs. I found this by weighin myself on a digital scale, then pickin up the wheel and re-weighing my self. Also, the 91 ls wheels weigh about 15 .5 lbs and are 14x5.5
the 15's=
the 14's=
should i use the 15's?
Old May 11, 2005 | 07:31 AM
fast2camciv's Avatar
hey tim is that what size tire you were using on your turbo z6? what kinda 60's were u gettin?
Old May 11, 2005 | 07:38 AM
99lspwr's Avatar
Default Re: turbo z6, what size bfg drag radials? (fast2camciv)
Stay away from 24s, thats way too tall for a single cam unless you are making big power...22s or23s wil be just fine..
Old May 11, 2005 | 10:33 AM
Timmay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv &raquo;</TD></TR><TR><TD CLASS="quote">hey tim is that what size tire you were using on your turbo z6? what kinda 60's were u gettin?</TD></TR></TABLE>
215/60/14 and i was cutting 2.0's open diff on them
that was on higher boost 16-17lbs
Old May 11, 2005 | 10:55 AM
so would you say go with the 14's for higher hp and 15's for lower hp? i know the section width is the same on both but does side wall height really make any difference besides gearing, on a drag radial??
Old May 11, 2005 | 11:02 AM
Timmay's Avatar
Default Re: (fast2camciv)
id say for 250 whp and under 205/50 is perfect, then 250+ go with 225/50 or 215/60
Old May 12, 2005 | 10:04 AM
PA MATT's Avatar
Default Re: (Timmay)
if i go with 205/50's, would the 18 lb 15x8 wheels or the 15.5 lb 14x5.5's?????
Old May 15, 2005 | 02:03 PM
dj4monie's Avatar
Default Re: (PA MATT)
I think what they are trying to say -
Stick with close to the stock tire size to around 250hp. Anything higher would need a higher final drive (taller tire) to help with traction woes and keeping it out of 5th gear at the end of the strip.
So in your case -
Use the heavier 15" wheel and BFG 205/50-15 tires.
Old May 15, 2005 | 07:56 PM
PA MATT's Avatar
Default Re: (dj4monie)
okay, thanks for the help guys...gonna be ordering these soon
Old May 18, 2005 | 06:23 PM
smokey2.0's Avatar
i would tell you to try the 215/60/14r, i'm using them on my low 200(less than 210 lol)whp engine. i have gatten two 1.9 60' times, but the tire is too big for the power i'm puting to the wheels. it's like running a 24.5" slick, since they are 24.2" tall. i think these tires will fit your set up just right, as you'll be able to put most of your power to the ground without over powering the tires!
EJ8 GSR-T
Feb 4, 2008 12:07 PM
FULL throTTLe
Mar 9, 2006 09:43 PM
boostincoupe
Mar 3, 2006 08:29 AM
teefunk01
Aug 11, 2005 06:13 AM
91 POS
Oct 15, 2003 09:52 AM
